jma_1
Posted: Sun Feb 18, 2007 6:46 pm |
Greetings,
Encoders are usually open collector outputs. You will need to have a pull up on the signal. I do not know which type of encoder you are using, absolute or incremental, but either might work fine depending on your application. The output of the encoder can be in quadrature, or a pulse train with a direction signal (high or low depending on motion). There might be a third option, but I cannot remember.
For more information on test circuits and connections, check out any of the manufacturer's websites.
A quick reference site is
http://www.motion-control-info.com/encoder_glossary.html
Cheers,
JMA |
