WHUNG.JOHN Guest
NOT USE SPI CONNECTION TO 74LS164 |
Posted: Sat Feb 10, 2007 12:17 pm |
hi! every teachers.
today i start learn different connect to 74ls164.
and not application spi mode. so i use direct control mode.
but i try written a sample . now still can't find question position.
hope every teacher can tell me ,where is error?
thanks.
follow as :
#include <16F877.h>
#use delay(clock=10000000)
#fuses NOWDT,HS,NOLVP,BROWNOUT
#include <LCD>
void write_expanded_outputs(BYTE* eo) {
BYTE i;
output_low(PIN_C3);
for(i=1;i<=8;++i) { // Clock out bits from the eo array
if(((*(eo))&0x80)==0)
output_low(PIN_C1);
output_high(PIN_C1);
shift_left(eo,1,0);
output_high(PIN_C3);
output_low(PIN_C3);
void init74164(void)
output_low(PIN_C2);
DELAY_MS(100);
//output_high(PIN_C1);
unsigned int da;
char a[]={0x80,0xeb,0x4c,0x49,0x2b,0x19,0x38,0x8b,0x08,0x0b};
init74164();
da=0xf7;
lcd_gotoxy(1,1);printf(lcd_putc,"\ftest=%4u",a[0]);
write_expanded_outputs(A[0]);
delay_ms(3000);
//WHILE(1);
while(1); |
Posted: Sat Feb 10, 2007 5:31 pm |
Hard to say where the error is when you don't give more details. How is your hardware connected? What is the error? What results do you get, and what are you expecting to see?
One error I spotted at a quick glance is that you are passing write_expanded_outputs() a character, while it expecting the _address_ of a character.
Change Code: | write_expanded_outputs(A[0]); | to Code: | write_expanded_outputs(&A[0]); |
whung.john Guest
sorry, i have not explain hardware connected. |
Posted: Sun Feb 11, 2007 1:51 am |
ckielstra wrote: | Hard to say where the error is when you don't give more details. How is your hardware connected? What is the error? What results do you get, and what are you expecting to see?
hi.senior .
sorry i have not to explain clearly.
First ,i connect to chip(74ls164),because 74ls164 have 3 address pin must connected.
so i connected method follow as:
clock pin =>pin_c3
serial input pin=>pin_c1
clear pin =>pin_c2
and 74lS164 output area pin connected a 8 number led display.
hope u can suggest me ,how can i modify that my sample program error.
thank u very much. |
Posted: Sun Feb 11, 2007 5:31 am |
Check init74164(), you set the Clear pin low but never high again. |
whung.john Guest
modified program and issue a question |
Posted: Wed Feb 14, 2007 8:29 am |
ckielstra wrote: | Check init74164(), you set the Clear pin low but never high again. |
hi.sir .
i modified program.follow as
issue display number 1 to 9.and stop not display.
please teach me ,where id the program have error ?
#include <16F877.h>
#include <LCD>
//!//74164CLK = PIN_C3 SCK=CLOCK
//74164_DO = PIN_C5 output資料
//74164_CLEAR = PIN_C4 清除74164內資料 可任何PIN腳位
void write_74164(BYTE* eo) {
BYTE i;
// output_low(PIN_C3);
output_low(PIN_C1);
shift_left(eo,1,0);
output_low(PIN_C3);
output_low(PIN_C2); //清除74164資料
DELAY_MS(100);
output_high(PIN_C2); //清除74164資料
output_low(PIN_C3); //clock l
output_high(PIN_C3);//clock h
unsigned int da,i;
char a[]={0x80,0xeb,0x4c,0x49,0x2b,0x19,0x38,0x8b,0x08,0x0b,0xff};
init74164();
da=0xf7;
for (i=0;i<11;i++)
write_74164(&A[i]);
write_74164(&A[10]);
Posted: Wed Feb 14, 2007 10:46 am |
First, when posting code, please use the 'Code' buttons in order to preserve the layout of your code. Easier reading will get you quicker and better answers.
The 74164 clocks data in at the rising edge. In init74164() you have Code: | output_low(PIN_C3); //clock l
| This has two problems,
1) You are clocking in undefined data.
2) You leave the clock signal at a high level.
Code: | //!//74164CLK = PIN_C3 SCK=CLOCK
//74164_CLEAR = PIN_C4 清除74164內資料 可任何PIN腳位 | These pin descriptions are not equal to the connections from your previous post.
Make life easier to yourself by creating subtitute names for the pin numbers: Code: | #define CLK_74164 PIN_C3
#define D0_74164 PIN_C1
#define CLR_74164 PIN_C2 |
I remember someone else having similar problems a few weeks ago. I don't know where you got your code from, but it is a modifed version from the CCS 74595.c example. Problem with this CCS code is that it is destructive, once a character is displayed the value is set to all zeroes and fails the next time.
The easiest solution is to change the write_74164() function to not get an address as parameter, but to pass the value to be displayed.
Code: | #include <16F877.h>
#include <LCD.C>
void write_74164(BYTE eo)
int8 i;
for (i=0; i<8; i++) // Clock out bits from the eo array
if ((eo & 0x80) == 0)
output_low(D0_74164);
output_high(D0_74164);
shift_left(&eo,1,0);
output_high(CLK_74164);
output_low(CLK_74164);
// Initialize clock line
// Clear all outputs
output_low(CLR_74164);
output_high(CLR_74164);
const char a[]={0x80,0xeb,0x4c,0x49,0x2b,0x19,0x38,0x8b,0x08,0x0b,0xff};
int8 i;
init74164();
for (i=0; i<11; i++)
write_74164(a[i]);
Note the character array a[] is a never changing constant. I changed 'char a[]' to 'const char a[]', this moves the array from RAM to ROM, saving both in ROM and RAM usage. |
whung.john Guest
thanks u very much.if i must connected 2 74ls164? |
Posted: Fri Feb 16, 2007 11:46 am |
ckielstra wrote: | First, when posting code, please use the 'Code' buttons in order to preserve the layout of your code. Easier reading will get you quicker and better answers.
#include <LCD>
int8 i;
int8 i;
init74164();
write_74164(a[i]);
ckielstra:
thanks u very much. i can from taiwan get u suggest.
i am very happy.
the night ,i modified my bad program . and hard to learn .
i get a good medtod from u description suggest.
but i tested finish.
next tested homework ,i hope to connected 2 74ls164.
but i dont know how modified .and first area.
can u suggest me? again get me a clew. |
Posted: Fri Feb 16, 2007 12:51 pm |
We are not here to do your homework. This sounds hard, but that's how the world is. If we give you the solution right now than you will not learn how to solve problems like these. I already have enough colleagues who can't think by themselves.
Please try to think of a solution yourself first. Than when you can't get it to work post your code and we will try to help you. |
