NathanI Guest
Using a union inside a struct |
Posted: Fri Feb 16, 2007 1:30 pm |
Hi, I did a forum search, but didn't find anything that matched my question. Basically I want to do this:
typedef union _CALDATA
unsigned int16 word;
signed int16 sword;
struct
byte L;
byte H;
} BYTES;
} CALDATA;
typedef struct
CALDATA minVal;
CALDATA maxVal;
CALDATA curVal;
} MINMAXCAL;
This compiles fine, but when I reference it by doing this:
myVarArray[5].minVal.word = 0x0000;
Compiler says
*** Error 57 "**Location**" Line 753(37,43): Expecting a structure/union
Please let my know if this is possible, thanks in advance.
P.S. I am using compiler version 3.184 and I replace my directory with **Location**. |
Posted: Fri Feb 16, 2007 4:12 pm |
I don't see any actual declaration of 'MyVarArray'.
It compiles fine on 3.163, 1nd 3.191 (the two nearest versions I have to 3.184), with:
// First declare the data type
typedef union {
signed int16 sword;
struct {
byte L;
byte H;
} BYTES;
} CALDATA;
//Now a structure of these types
typedef struct {
CALDATA minVal;
CALDATA maxVal;
CALDATA curVal;
} MINMAXCAL;
//Now declare the array
MINMAXCAL MyVarArray[10];
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
//Now access the array
MyVarArray[5].minVal.word=0x0L;
This correctly uses 60 bytes, and the list shows the correct 16bit word being accessed.
Posted: Fri Feb 16, 2007 5:14 pm |
Wow, yeah sorry for wasting your time. I had declared it not as an array. Forgot to adjust my temp variable. |
