spi_clock
gianni_pancrazi
spi_clock
PostPosted: Tue Feb 13, 2007 7:23 am     Reply with quote
I have to get an output from a 18 bit ADC converter working with SPI-Bus. I'm writing my Program with a CCS-C compiler and I'm working with a PICF4620. I have not a great experience with PIC programming. I would like to acquire the data with a "spi_read()" Function. SCKL (PIN_C3) is my serial clock.
How does the ADc get the serial clock?
Should I use the standard command line, like follow:
 setup_spi (spi_master |spi_l_to_h | spi_clk_div_16 )
or better to write a my own clock program like:
output_toggle(SCKL);
Thank u for your Help
Andrea
PostPosted: Tue Feb 13, 2007 10:18 am     Reply with quote
Post the manufacturer and part number of the ADC chip.
PostPosted: Tue Feb 13, 2007 11:02 am     Reply with quote
On the second part of the question, the hardware SPI, is faster, and easier to use. The send a byte using software toggling, is hard work...
gianni_pancrazi
Controlling AD7691
PostPosted: Wed Feb 14, 2007 7:41 am     Reply with quote
I'm using a differential ADC, from Analog Devices (AD7691). The configuration used is a 4-Wire CS Mode with Busy Indicator (see page 21/28 of the datasheet). With a pull-up on the SDO line, I can get an interrupt signal to initiate the data readback controlled by the PIC. For readback I'm using this code:
#include<Header.h>
#device *=16
#use delay(clock=16000000)
#define LED1 PIN_B2
#define LED2 PIN_B3
#define SDI    PIN_C4
#define SDO  PIN_C5
#define SCKL PIN_C3
#define CNV  PIN_A4
int16 x=0;
int a;
int i;
setup_spi(spi_master | spi_l_to_h | spi_clk_div_16 );
output_low(SCKL);
output_high(SDO);
output_high(CNV);
output_low(SDO);
delay_us(0.4);
while (TRUE)
 {   a=spi_read();
   if (a==0)
            for (i=0;i<=17;++i)
               output_high(SCKL);
               delay_us(10);
               output_low(SCKL);
               if( spi_data_is_in()) bit_set(x,(i));
               delay_us(10);
                  printf("\n %x", x );
} // main() END
The problem is, that I don't get a right result in conversion of input voltage. Do you have any suggestion?
Thank you very much for your help.
PostPosted: Wed Feb 14, 2007 12:33 pm     Reply with quote
You appear to be mixing hardware and software SPI. That's wrong.
You should use one or the other, but don't mix them.
gianni_pancrazi
ADC Acquisition
PostPosted: Thu Feb 15, 2007 10:03 am     Reply with quote
What are u meaning with mixing Hardware and Software? Could u be more explicit? Question
I have a stupid question Embarassed
Do I have to manually turn the clock up and down, during acquisition of ADC output? Like:
for(i=18;i>0;--i)
               output_low(SCKL);
               output_high(SCKL);
               delay_cycles(1);
Or the SPI function
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
will provide the CLK automatically?
PostPosted: Thu Feb 15, 2007 1:20 pm     Reply with quote
If you use the hardware SPI module, you can do a read operation
and the hardware module will generate the clock for you.
int8 c;
c = spi_read(0);
This code will send a byte of 0x00 on the SDO pin, and a clock
will be generated on the SCLK pin to do this. At the same time,
the incoming data from the SPI slave will be clocked in on the
SDI pin of the PIC.
The code shown above is the standard way to generate a clock
and read a byte from an SPI slave, while using the hardware SPI
module in the PIC.
