Corta
| #INT_RDA on PIC18F2620 |
Posted: Tue Feb 13, 2007 3:01 pm |
I use wireless module to communicate with a pc, it use RS232. My electronic is perfect but i have a problem with my program. I use rda_isr() but i cannot read the receive buffer.
| Code: | #include <18F2620.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, NOIESO, BROWNOUT, BORV21, NOPUT, NOCPD, NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, LPT1OSC, MCLR
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
#include "C:\MAX\Marche\marche.h"
#include "C:\MAX\Marche\moteur.c"
int Positions[10][6] = {
{1500,1500,1500,1500,1500,1500},
{1500,1500,1400,1500,1500,1400},
{1625,1600,1400,1600,1600,1400},
{1625,1600,1500,1600,1600,1500},
{1625,1600,1600,1600,1600,1600},
{1500,1500,1600,1500,1500,1600},
{1400,1400,1600,1400,1400,1600},
{1400,1400,1500,1400,1400,1500},
{1400,1400,1400,1400,1400,1400},
#int_RDA
RDA_isr()
int iCommande = -1;
int i,j,k;
iCommande = getc();
if(iCommande == 0x55)
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_RDA);
output_bit(PIN_C4, 1);
output_bit(PIN_C5, 0);
If i transmit 0x55 it receive it but if i try just if(iCommande) it works with anything i transmit.
thanks
Max |
Posted: Tue Feb 13, 2007 5:30 pm |
| Quote: | | #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9) |
Why did you specify 9 data bits ? The normal number is 8 data bits.
I suggest that you use this statement instead:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS) |
| Quote: | int Positions[10][6] = {
{1500,1500,1400,1500,1500,1400}, |
In CCS, an 'int' is an unsigned 8-bit integer. So your array declaration
above will not work. You want to store 16-bit values in the array,
so you should declare it as a 'int16' array. Example:
| Quote: | int16 Positions[10][6] = {
