shen Guest
I2C don't work using 2 pics |
Posted: Tue Feb 13, 2007 10:13 pm |
Hello all,
I use a 16F877 as a master and a 16F873A as a slave.but they don't work.
here is the code
master
#include "16F877.h"
#use delay(clock=4000000) // for 4Mhz crystal
#fuses XT, NOWDT, NOPROTECT, PUT,NOLVP // for debug mode
#use I2C(master,sda=PIN_C4,scl=PIN_C3,FORCE_HW)
// These pins are for the Microchip PicDem2-Plus board,
// which is what I used to test the driver. Change these
// pins to fit your own board.
#define LCD_DB4 PIN_B4
#define LCD_DB5 PIN_B5
#define LCD_DB6 PIN_A5
#define LCD_DB7 PIN_B3
#define LCD_E PIN_A1
#define LCD_RS PIN_A3
#define LCD_RW PIN_A2
// If you only want a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line.
#define USE_LCD_RW 1
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the 2nd line
//char mode;
int8 DataA1;//DataA2,DataA3;
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Func set: 4-bit, 2 lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note: !! converts an integer expression
// to a boolean (1 or 0).
output_bit(LCD_DB4, !!(nibble & 1));
output_bit(LCD_DB5, !!(nibble & 2));
output_bit(LCD_DB6, !!(nibble & 4));
output_bit(LCD_DB7, !!(nibble & 8));
delay_cycles(1);
output_high(LCD_E);
delay_us(2);
output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine. For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_LCD_RW
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_cycles(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
return retval;
// Read a byte from the LCD and return it.
#ifdef USE_LCD_RW
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4>> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
output_low(LCD_RS);
#ifdef USE_LCD_RW
output_low(LCD_RW);
output_low(LCD_E);
delay_ms(15);
for(i=0 ;i < 3; i++)
lcd_send_nibble(0x03);
delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
lcd_send_byte(0, LCD_INIT_STRING[i]);
// If the R/W signal is not used, then
// the busy bit can't be polled. One of
// the init commands takes longer than
// the hard-coded delay of 60 us, so in
// that case, lets just do a 5 ms delay
// after all four of them.
#ifndef USE_LCD_RW
delay_ms(5);
void lcd_gotoxy(int8 x, int8 y)
int8 address;
if(y != 1)
address = lcd_line_two;
address=0;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
switch(c)
case '\f':
lcd_send_byte(0,1);
delay_ms(2);
case '\n':
lcd_gotoxy(1,2);
case '\b':
lcd_send_byte(0,0x10);
default:
lcd_send_byte(1,c);
#ifdef USE_LCD_RW
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
output_high(LCD_RS);
value = lcd_read_byte();
output_low(lcd_RS);
return(value);
// The lcd_init() function should always be called once,
// near the start of your program.
SET_TRIS_B( 0x0F );
SET_TRIS_A( 0x00 );
lcd_init();
// Clear the LCD.
printf(lcd_putc, "\f");
// Test the clear screen and newline commands.
// Also test that we can write to all 2 lines.
//printf(lcd_putc, "\fThis is the 1st");
//printf(lcd_putc, "\nNext is the 2nd");
///delay_ms(3000);
// Test some additional characters.
//printf(lcd_putc, "\fABCDEFGHIJKLMNOP");
//printf(lcd_putc, "\nabcdefghijklmnop");
//delay_ms(3000);
// Clear the LCD.
//printf(lcd_putc, "\f");
//delay_ms(500);
//delay_ms(250);
//printf(lcd_putc,"Master start \n\r");
//Slave A
i2c_start();
i2c_write(0xa0 + 1); // read
//DataA1=i2c_read(1);
//DataA2=i2c_read(1);
DataA1=i2c_read(1);
i2c_stop();
printf(lcd_putc,"\f %d ",DataA1);//,DataA2,DataA3);
slave
[/code]#include <16F873A.h>
#use delay(clock=10000000)
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0)
BYTE address, buffer=0;
#INT_SSP
void ssp_interupt ()
BYTE incoming, state;
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
incoming = i2c_read();
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer = incoming;
if(state == 0x80) //Master is requesting data
i2c_write(buffer++);
void main ()
enable_interrupts(INT_SSP);
while (TRUE) {}
Posted: Tue Feb 13, 2007 11:05 pm |
You've created a modified version of the CCS example code for an
i2c slave. You're using a single byte as the buffer, instead of an array.
That should still work. I think the problem is in your Master code.
See the following post for sample Master code that shows how to talk to
to CCS Ex_Slave.c code:
http://www.ccsinfo.com/forum/viewtopic.php?t=28097&start=9 |
shen Guest
Posted: Wed Feb 14, 2007 2:25 am |
[/quote]
i2c_start(); //i2c start
i2c_write(0xA0); //address
i2c_write(0x00); // ?????
i2c_start();
i2c_write(0xA1); //ready to read
data = i2c_read(0);
i2c_stop();
printf("read %c \n\r", data);
what does it mean? |
