V4.023 mplabv7.5 windows 2k
hwk
PostPosted: Mon Feb 12, 2007 6:37 am     Reply with quote
recently upgraded MPLAB to 7.5 and ccs to 4.023. I'm running windows 2K. Now mplab crashes quite often. Typically during the compile but not always. Sometimes MPLAB will abruptly close. This is with code that I've used for years with no problem. Any one experiencing these problems. I suppose I should have upgraded one and waited a while before upgrading the other. I don't want to return to previous versions of either program.
Any help will be greatly appreciated
mindstorm88
PostPosted: Mon Feb 12, 2007 7:23 am     Reply with quote
i do run MPLAB 7.50 and CCS 4.023 on WIN2k SP4 without any problem !!! Maybe you should uninstall everything from control panel , then install mplab first , ccs 4.023 and ccs mplab patch (unless it get installed by 4.023 )
