cfernandez
Power Distribution Switches Question |
Posted: Fri Feb 09, 2007 10:38 am |
In my design I have multiples voltage input (USB, Jack, etc.) and I need a circuit that I when connect USB block the other voltage input, or if I connect the Jack block the USB input.
I see the Texas Instrument IC TPS2082, but I want to know if exist other way for make this in my design??
Any have a answer??
Thank you very much!!
Best Regards, |
libor
Posted: Fri Feb 09, 2007 5:04 pm |
What about two diodes with common cathodes at the ps input ? The higher voltage will supply your circuit. I suggest Schottkies because of their lower voltage drop value. |
cfernandez
Posted: Fri Feb 09, 2007 5:19 pm |
Can you send me a little circuit?, I cannot drop voltage in my design.
Best Regards, |
