kocakaya Guest
Need Advice Urgent |
Posted: Sat Feb 10, 2007 6:15 am |
I made a 100 A car battery charger .There is 2x20 LCD and AN0 is Current Value Input AN1 is Voltage input. I want to write 24LC512 RAM and send to pc with Int_rda charging results. when battery voltage higher I am showing it with leds . My code is below Do you think is there a wrong in code When voltage is higher lcd showing speed gets faster because of led delays .Timers hold the amper hour .what can you advice ?
void besli() {
OUTPUT_HIGH(PIN_D4);
delay_ms(300);
OUTPUT_LOW(PIN_D4);
delay_ms(300);
OUTPUT_HIGH(PIN_C5);
delay_ms(300);
OUTPUT_LOW(PIN_C5);
delay_ms(300);
OUTPUT_HIGH(PIN_D3);
delay_ms(300);
OUTPUT_LOW(PIN_D3);
delay_ms(300);
OUTPUT_HIGH(PIN_D2);
delay_ms(300);
OUTPUT_LOW(PIN_D2);
delay_ms(300);
OUTPUT_HIGH(PIN_C2);
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void dortlu() {
delay_ms(300);
OUTPUT_LOW(PIN_C5);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_D3);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_D2);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void uclu() {
delay_ms(300);
OUTPUT_LOW(PIN_D3);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_D2);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void ikili() {
delay_ms(300);
OUTPUT_LOW(PIN_D2);
delay_ms(300);
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void tekli()
delay_ms(300);
OUTPUT_LOW(PIN_C2);
delay_ms(300);
void akimgerilim()
int adcdeger;
set_adc_channel( 1 );
delay_us(1);
value = Read_ADC();
deger=value/51;
value=value/51;
delay_us(1);
set_adc_channel( 0 );
delay_us(1);
adcdeger=Read_ADC();
max=adcdeger*1.5;
delay_us(1);
#INT_RDA
void yaz()
#INT_RTCC
void clock_isr() {
high_count -= 1;
akimgerilim();
if(high_count==0)
++seconds;
high_count=high_start;
ahtoplam=ahtoplam+(max/3600);
if(seconds>=60)
dakika++;
seconds=0;
if(dakika>=60)
saat++;
dakika=0;
#int_TIMER1
void clock_isr2()
high_count2 -= 1;
if(high_count2==0)
++seconds2;
high_count2=high_start;
if(input(PIN_C1)==1)
dakika2=dakika2+10;
seconds2=0;
if( input(PIN_C1)!=1 )
if(seconds2>=60)
dakika2++;
seconds2=0;
if(dakika2>=60)
saat2++;
dakika2=0;
lcd_init();
init_ext_eeprom();
setup_adc_ports(AN0_TO_AN1|VSS_VDD);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_bit);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
enable_interrupts(INT_RTCC);
enable_interrupts(INT_RDA);
set_timer0(0);
do {
lcd_putc("\f");
delay_ms(1);
lcd_gotoxy(1,1);
lcd_putc(" M K P Micro ");
lcd_gotoxy(1,2);
lcd_putc(" Akuyu Baglayiniz");
delay_ms(200);
do {
output_high(PIN_D7);
delay_ms(250);
output_low(PIN_D7);
delay_ms(250);
}while (deger<1);
OUTPUT_HIGH(PIN_D7);
lcd_putc("\f");
delay_ms(1);
lcd_gotoxy(1,1);
lcd_putc(" Aku Baglandi\n");
lcd_gotoxy(1,2);
lcd_putc(" Bekleyiniz");
for(a=0;a<3;a++)
OUTPUT_D(0x9F);
delay_ms(450);
OUTPUT_D(0x00);
OUTPUT_LOW(PIN_C5);
OUTPUT_LOW(PIN_C2);
delay_ms(450);
lcd_putc("\f");
if(deger<1>2.40)
ariza=3;
goto ariza10;
OUTPUT_HIGH(PIN_D5);
delay_ms(2000);
system_start=1;
set_timer1(0);
asama=1;
dakika=0;
saat=0;
seconds=0;
ahtoplam=0;
ilk=0;
kademe=0;
lcd_putc("\f");
delay_ms(1);
do {
ariza=0;
if(ilk==0)
ilk=1;
if(max<2)
ariza=5;
if(max<2)
islemtamam=0;
a1=0;
ariza=4;
lcd_gotoxy(1,1);
printf(lcd_putc,"V:%01.2f ", value);
lcd_gotoxy(12,1);
printf(lcd_putc,"Ah:%2f.1",ahtoplam);
lcd_gotoxy(1,2);
printf(lcd_putc,"I:%03.1f ",max);
lcd_gotoxy(13,2);
printf(lcd_putc,"T:%02u:%02u",saat,dakika);
if(value<2>=2.10 && value<2>=2.20 && value<2>=2.30 && value<2.40 && kademe==0)
ikili();
if(asama==4 || asama==5 || asama==6 || asama==7 || asama==8 || asama==9)
tekli();
if(saat2==10 && value<2>=2.30) && asama==1))
asama=2;
saat2=0;
dakika2=0;
seconds2=0;
if(((saat2==2 && dakika2==30) && value<2>=2.35) && asama==2)
asama=3;
saat2=0;
dakika2=0;
seconds2=0;
if(((saat2==1 && dakika2==30) && value<2>=2.40) && asama==3)
asama=4;
kademe=1;
saat2=0;
dakika2=0;
seconds2=0;
if(((saat2==1 && dakika2==30) && value<2>=2.45) && asama==4)
asama=5;
saat2=0;
dakika2=0;
seconds2=0;
if(((saat2==1 && dakika2==30) && value<2>=2.50) && asama==5)
asama=6;
zaman=0;
saat2=0;
dakika2=0;
seconds2=0;
if(((saat2==1 && dakika2==30) && value<2>=2.55) && asama==6)
asama=7;
saat2=0;
dakika2=0;
seconds2=0;
if(((saat2==1 && dakika2==30) && value<2>=2.6) && asama==7)
asama=8;
saat2=0;
dakika2=0;
seconds2=0;
if(((saat2==1 && dakika2==30) && value<2>=2.65) && asama==8)
asama=9;
saat2=0;
dakika2=0;
seconds2=0;
if(saat2==1 && asama==9)
islemtamam=1;
ariza=6;
if(saat==14 && value<2>2.40)
islemtamam=1;
ariza=6;
}while (TRUE);
Thanks for help |
