PIC18F4520 Development Kit Comment & Question Exercise 7
The_Todd
PostPosted: Sun Feb 11, 2007 6:23 pm     Reply with quote
First of all, I just bought the development kit with the student discount and am really enjoying it. I'm working through the exercise book, and am have a few troubles with example 7.
The example reads a POT on A0 and looks like this:
#include <prototype.h>
#include <utility.c>
#define cutoff 128      //2.5 volts
#define neutral_zone 25 // .5 Volts
   int reading;
   setup_adc_ports( RAO_ANALOG );
   setup_adc( ADC_CLOCK_INTERNAL);
   set_adc_channel( 0 );
   while(true) {
      reading = read_adc();
      if(reading<cutoff>(cutoff+neutral_zone/2))
         light_one_led(RED);
         light_one_led(YELLOW);
I believe that RA0_ANALOG is an error because it is not defined in the H file, after doing some digging, replacing RA0_ANALOG with AN0 makes the program work correctly (FUN!), I thought I should let you know for the next printing.
Here is my real question:
Also with the Further Study in Exercise 7 part A, it suggests adding ADC=16 to the #device ICD=TRUE line. "this will change the range to 0-1023".
I did that, but the range is definitely not 0-1023. Putting a watch on the reading variable, I get various values with the POT between 0-192. I am guessing this is because the reading variable is a INT (maximum 255, right?), so I change int reading; to long reading;, but then I get values between 128-38976.
Can someone help me with this?
Thanks,
Todd
The_Todd
PostPosted: Sun Feb 11, 2007 7:05 pm     Reply with quote
So with a little more digging i've found that the answer to my question is that there is another error in exercise 7. Anyways, it should suggest adding ADC=12, as this will return a range of 0-1023, while ADC=16 will return 0-65472. It should also suggest changing reading to a long.
CCS was having some trouble "stepping over" reading = read_adc(), but "run to cursor" to the next line returned good values.
Todd
Storic
PostPosted: Sun Feb 11, 2007 7:33 pm     Reply with quote
you have to ask yourself, are the question deliberately incorrect so you have to debug/find the fault to make it work.
forces you to understand the answer over parrot fashion learning.
I have always learn't more by mistakes than getting it right 1st time.
Andrew
What has been learnt if you make the same mistake? Wink
newguy
PostPosted: Sun Feb 11, 2007 7:36 pm     Reply with quote
Andrew
Amen.
dyeatman
PostPosted: Sun Feb 11, 2007 8:24 pm     Reply with quote
The_Todd,
Thanks for the info for those here who might benefit. It sounds like you are coming along nicely!
However, as you might have noticed at the top of the web page, it says CCS doesn't monitor this page and to send bug reports to support@ccsinfo.com
I think they might appreciate the feedback on the kit....
Hang in there and, as you said earlier, have fun!!!
