kjkim Guest
Compiler v4 error |
Posted: Thu Feb 08, 2007 12:02 am |
Hello.
I'm working PIC18F65J10 and PIC18F66J15
I have some question about that with v4 compiler
First Q.
I' try to same source program
good in v3.249 but bad in v4.016
second Q.
same source program but difference device
PIC18F65J10 is good but PIC16F66J15 is bad in ver3.249
Why is it?
Bonus Q.
setup_ccp error
//setup_ccp1(ccp_off); // occured error
//setup_ccp2(ccp_off); // occured error
//setup_ccp3(ccp_off); // occured error
//setup_ccp4(ccp_off); // occured error
//setup_ccp5(ccp_off); // occured error
ccp1con=0x00;
ccp2con=0x00;
ccp3con=0x00;
ccp4con=0x00;
ccp5con=0x00;
See the bellow summary source
#include "18f65J10.h"
//#include "18f66J15.h"
#FUSES HS,PROTECT,NODEBUG,NOFCMEN,NOIESO,STVREN,WDT4096,NOXINST
#ID 0x06,0x12,0x18,0x00
#ZERO_RAM
#priority timer1,ext1,ext,rtcc,timer2
#use delay(clock=16000000, restart_wdt)
#use rs232(baud=19200,xmit=pin_c6)//,rcv=pin_c7)
#include "math.h"
#INT_EXT1
void ext1_isr()
sleep_flag=TRUE;
#INT_TIMER1
void RTC_isr() //RTC ROUTINE
byte temp_hour_data;
TMR1H=0x80; TMR1L=0x00;
#INT_EXT
void ext_isr()
enable_interrupts(INT_RTCC);
//etc description
#INT_RTCC
void rtcc_isr()
disable_interrupts(INT_RTCC);
//etc description
#INT_TIMER2 //key and dispaly(FND,LED) routine
void timer2_isr()
set_tris_a(0xff);
set_tris_b(0xff);
set_tris_c(0x01);
set_tris_d(0x00);
set_tris_e(0x30);
set_tris_f(0xc0);
set_tris_g(0x00);
port_b_pullups(FALSE);
lata=0;
latb=0;
latc=0;
latd=0;
late=0;
latf=0;
latg=0;
sleep_flag=FALSE; // init sleep flag
ccp1con=0x00;
ccp2con=0x00;
ccp3con=0x00;
ccp4con=0x00;
ccp5con=0x00;
//setup_spi(SPI_SS_DISABLED);
SSP1CON1=0x01;
SSP1STAT=0x00;
//setup_spi2(SPI_SS_DISABLED);// occured error
SSP2CON1=0x01;
SSP2STAT=0x00;
setup_psp(psp_disabled);
setup_adc_ports(AN0|VSS_VDD); // A3, A5, E0, E1, E2 -> ANALOG
set_adc_channel(1);
ext_int_edge(L_TO_H); //fsk in
ext_int_edge(1,H_TO_L);
setup_counters(RTCC_8_BIT,RTCC_DIV_64);
setup_wdt(WDT_ON);
//setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
//setup_timer_2(T2_DIV_BY_4,0xfa,6);//@6Mhz
setup_timer_2(T2_DIV_BY_16,0x64,10); // the timer will include every 4uS,
// will overflow every 0.4mS and will interrupt every 4mS
SETUP_TIMER_3(T3_INTERNAL|T3_DIV_BY_8);//the timer will increment every 2us.
//It will overflow every 131.072ms.
//setup_OSCILLATOR(OSC_NORMAL);
disable_interrupts(INT_BUSCOL);
disable_interrupts(INT_BUSCOL2);
disable_interrupts(INT_RDA);
disable_interrupts(INT_RDA2);
disable_interrupts(INT_SSP);
disable_interrupts(INT_SSP2);
disable_interrupts(INT_PSP);
disable_interrupts(INT_RB);
disable_interrupts(INT_CCP1);
disable_interrupts(INT_CCP2);
disable_interrupts(INT_CCP3);
disable_interrupts(INT_CCP4);
disable_interrupts(INT_CCP5);
disable_interrupts(INT_COMP);
disable_interrupts(INT_OSCF);
disable_interrupts(INT_TBE);
disable_interrupts(INT_TBE2);
disable_interrupts(INT_AD);
disable_interrupts(INT_EXT2);
disable_interrupts(INT_EXT3);
disable_interrupts(INT_TIMER3);
disable_interrupts(INT_TIMER4);
enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
//**************RTC_init****************//
TMR1L=0x00; //Preload TMR1 register pair
TMR1H=0x80; //for 1 second overflow
T1CON=0x0f; // Configure for external clock,
//Asynchronous operation, external oscillator
sec_data=0; // Initialize timekeeping registers
min_data=0;
hour_data=12;
enable_interrupts(INT_TIMER1); // Enable Timer1 interrupt
while(TRUE){//main program description
if(sleep_flag)sleep();// if sleep flag set make processor sleep
CCS Technical Support does not monitor this forum on a regular basis. Please do not post bug reports to this form. All bug reports should be emailed to support@ccsinfo.com. Thank you. |
