Setting up ADC
Student
Setting up ADC
PostPosted: Thu Feb 22, 2007 7:16 am     Reply with quote
i'm trying to write a program to run setup my adc and i'm getting problems and i do not know the reason why. Anyone can help me? Thanks!
#include <16F877.h>
#device adc=10
#use delay(clock=2000000)
#use rs232(baud=9600, xmit = PIN_C6, rcv = PIN_C7)
int16 value;
void main() {
   setup_adc_ports(RA0_ANALOG);
   delay_ms(2000);
   set_adc_channel(0);
      value=read_adc(); //read the ADC
     printf("%LX \n\r", value);
Output from hyperterminal:
rrrrr>>>>><<<<>>>>[/code]
PostPosted: Thu Feb 22, 2007 9:39 am     Reply with quote
How is the serial connected to the PC?. What happens if you do a 'test' print like:
printf("Test message\n\r");
There is nothing obviously wrong with the code, so I'd suspect a hardware problem with the serial connection.
buiz
PostPosted: Thu Feb 22, 2007 9:48 am     Reply with quote
Hello!
#include <16F877.h>
#device adc=10
#use delay(clock=2000000) // crystal 2000000? or 20000000? look at this detail!!!
int16 value;
void main() {
setup_ADC_ports (an0); // (an0) it configures door an0
delay_ms(2000);
set_adc_channel(0);
Ok!
PostPosted: Thu Feb 22, 2007 11:20 am     Reply with quote
rrrrr>>>>><<<<>>>>
#include <16F877.h>
#device adc=10
Look closely at the line in bold. Then look at the numbers on your
crystal.
