Passing data using pointers on a pic16f917
brood
PostPosted: Sun Jan 28, 2007 7:41 am     Reply with quote
Hi
I'm working on a mechanically scanned display. my problem is that when i look through the string and point to the constant array the out put i get is wrong. my display function was tested separate and it works, i would believe my error is in my character processing function.
Could some one please help, my code can be seen below.
#include <16F917.H>
#include <CTYPE.H>
#fuses INTRC_IO,NOPROTECT,NOWDT,PUT
#use delay(clock=8000000)
#use standard_io(a)
#use standard_io(b)
#use standard_io(c)
#use standard_io(d)
#case
// Global variables
int length;
int colour;
int16 stringptr;
//16X10 font map
const unsigned int16 A[10] = {0xFFF8, 0xFFFC, 0x0186, 0x0183, 0x0181, 0x0181, 0x0183, 0x0186, 0xFFFC, 0xFFF8}; //A
const unsigned int16 B[10] = {0xFFFF, 0xFFFF, 0xC183, 0xC183, 0xC183, 0xC183, 0xC183, 0xE3C7, 0x7FFE, 0x3E78}; //B
const unsigned int16 Z[10] = {0xF003, 0xF803, 0xCC03, 0xC603, 0xC383, 0xC1C3, 0xC063, 0xC033, 0xC01F, 0xC00F}; //Z
const unsigned int16 Number[10][10] =
      {0x3FFC, 0x7FFE, 0xC00F, 0xC03B, 0xC1E3, 0xC783, 0xDC03, 0xF003, 0x7FFE, 0x3FFC} //0
      {0x307C, 0x60FE, 0xC1C7, 0xC183, 0xC183, 0xC183, 0xC183, 0xE3C7, 0x7FFE, 0x3FFC} //9
   }; // number array
// Message
const int16 msg1[] ={"AB 12"};
// Output function
void display(int top, int bottom)
   switch (colour) {
      case 1:      // outputs red
         output_a(top); // display on the topline in red
         output_b(bottom); // display on bottomline in red
         delay_ms(2000);
      case 2:       // outputs green
         output_c(top); // display on the topline in green
         output_d(bottom); // displays on bottomline in green
         delay_ms(2000);
      case 3:         // outputs yellow
         delay_ms(2000);
      default:
         colour = 1;
// Character check
void Char_prosessing(int16 *charptr)
   length = 0;
   if (isalpha(charptr))
      if (length <= 10)
         display(make8(charptr[length],0), make8(charptr[length],1)); // splits the 16bit value into 2 8bit values and displays
         length++;
      } // end if
         display(0x00, 0x00);
   else if (isdigit(charptr))
      if (length <= 10)
         display(make8(Number[charptr][length],0),make8(Number[charptr][length],1));
         length++;
      } // end if
   else if (isspace(charptr))
      if (length <= 10)
         length++;
      } // end if
// Main Program
   setup_lcd(LCD_DISABLED);  // disables lcd display to access digital outputs
   length = 0;
   colour = 1;
   stringptr = 0;
   for (;;)
      if (msg1[stringptr] != '\0')
         Char_prosessing(msg1[stringptr]);
         stringptr++;
      } // end if
         stringptr = 0;
         if (colour <= 3)
            colour++;
         } //end if
            colour = 1;
         } //end else
      } //end else
Compiler version : 3.228
PostPosted: Sun Jan 28, 2007 10:09 am     Reply with quote
RTFM......
CCS, doeas not support pointers to constants. ou can either declare the data in RAM (get rid of the const keyword), or you have to access the array directly, not using pointers.
brood
PostPosted: Tue Jan 30, 2007 5:27 am     Reply with quote
Is there another way of doing the above without creating huge arrays in the ram? Because the PIC16F917 doesn't have enough ram to accomplish that.
Thank you in advance
PostPosted: Tue Jan 30, 2007 5:35 am     Reply with quote
Declare the array usng #ROM (which will directly store the sequence of bytes in memory), at a 'known' location (fixed by you), and then access it using the 'read_program_memory' function. The 16F914, is one of the few '16' chips, that supports doing this.
