Interfacing RTC and GSM
ratheeshbr
PostPosted: Tue Apr 03, 2012 12:13 am     Reply with quote
hi, I am tying to interface RTC DS1307 and GSM modem to control electrical devices. Both are working independently but not when integrated.
Here is my code.
#include <16F877A.h>
#define max 65534
#device *=16
#device adc=10
#include"pic.h"
#include"lcd1.h"
#include<string.h>
#use i2c(Master,Slow,sda=PIN_C4,scl=PIN_C3)
#include "ds1307.c"
#define h_sw rc0
#define m_sw rc1
#define s_sw rc2
#define set_sw
#define pir rd3
#define ir rd2
char num[15];
char msg[25];
char no3[12]="xxxxx";
char noofc[12]="xxxx";
int hon=0,mon=0,s,l;
int sethron();
int setmnon();
int sethrof();
int setmnof();
void mode100();
void mode0();
void mode50();
int hof=0,mof=0;
int setflg=0;
int lflg=0;
char ctr1[]="**D1ON";
char ctr2[]="**D2ON";
char ctr3[]="**D1OF";
char ctr4[]="**D2OF";
 msg_read(char *num,char *msg)
   char ch;
   int i,j,m;
   int1 flg=0;
   unsigned long  time;
   while(kbhit())
      ch=getch();
   if(ch=='"')
   while(ch!= '1')         ///Loop to reach to No
   if(kbhit())
         ch=getch();
         time=0;
      time++;
      if(time > max)
      return(0);
               //Extracting NO
         for(j=0;j<=12;)
               if(kbhit())
                     num[j]=getch();
                     j++;
            num[j]='\0';
      //   prints(num);
   //Extacting Message
         j=0;
            if(kbhit())
                     ch=getch();
                     if(ch==10)
                     flg=1;
                     time=0;
                        if(flg)
                              if(j>0)
                                    if(ch==10)
                                       {   j-=2;
                                          msg[j]='\0';
         go(64);
         //prints(msg);
                                          return(1);
                                 msg[j-1]=ch;
                              j++;
                  }//kbhit
sms_cntrl()
    msg_read(num,msg);
    if(msg_read(num,msg)==1)
                 if(!strcmp(ctr1,msg))
                    //mode50();
                    delay_ms(800);
                    clrscr();
                 //   sms1_on();
                    lflg=1;
                 else if(!strcmp(ctr3,msg))
                   // mode0();
                    delay_ms(800);
                    clrscr();
                //    sms1_of();
                    lflg=0;
                   delay_ms(1300);
                   clrscr();
                //   sms2_wrong();
void sms_start(char*ch)
   printf("AT+CMGS=");
   printf("\"%s\"\r",ch);
    void sms_send(void)
    putchar(26);
    delay_ms(200);
    void sms1_on()
    sms_start(num);
    printf("Device1 is ON");
    sms_send();
   void sms2_on()
    sms_start(num);
    printf("Device2 is ON");
    sms_send();
   void sms2_wrong()
    sms_start(num);
    printf("Wrong Format,Try **D_ON/OFF");
    sms_send();
   void sms2_me()
    sms_start(no3);
    printf("PAACET PJT IS ON");
    sms_send();
   void sms2_ofc()
      sms_start(noofc);
       printf("Street Light fault");
       sms_send();
   void sms1_of()
    sms_start(num);
    printf("Device1 is OFF");
    sms_send();
   void sms2_of()
    sms_start(num);
    printf("Device2 is OFF");
    sms_send();
    float ldr()
   set_adc_channel(0);
   delay_us(20);
   return(read_adc());
      byte sec;
         byte min;
        byte hrs;
       byte day;
       byte month;
        byte year;
         byte dow;
         char col[]=":";
         int m=35;
         int msgflg=1;
      trisb=0x00;
      trisc0=trisc1=trisc2=trisd0=1;
      trisd4=trisd5=trisd6=trisd7=0;
      trisd2=trisd3=1;
      enable_interrupts(INT_RDA);
        enable_interrupts(global);
      lcdinit();
      go(4);
      printc("xxxxx");
      go(64);
      printc("xxxxxxxxx");
      clrscr();
      mode0();
      sms2_me();
       setup_adc_ports(ALL_ANALOG);
//initialize 1307
 //ds1307_init();
 //ds1307_set_date_time(26,3,12,3,4,56,55); //day, month,year,dow,hr,min.sec
lflg=0;
           if(kbhit())
           sms_cntrl();
           mode50();
                sms_cntrl();
                      if(lflg)
                           if(ldr()>700)
                              if(msgflg)
                              sms2_ofc();
                               msgflg=0;
                ds1307_get_date(day,month,year,dow);
                    ds1307_get_time(hrs,min,sec);
                 sms_cntrl();
                   go(0);
                     print(hrs);prints(col);print(min);prints(col);print(sec);
                   go(76);
                  print(ldr());
              if(ir||pir)
              if(ir)
           mode100();
           delay_ms(2000);
         if(setflg)
            go(64);
            print(hon);prints(col);print(mon);printc("   ");
             print(hof);prints(col);print(mof);printc("   ");
           clrscr();
       if(rd0)
           printc("Press to set Time");
           sethron();
              setmnon();
              sethrof();
              setmnof();
           setflg=1;
       if(hon==hrs&&mon==min)
          mode50();
          hon=mon=0;
          setflg=0;
          lflg=1;
          if(pir||ir)
          mode100();
          mode50();
        if(hof==hrs&&mof==min)
          mode0();
          lflg=0;
          hof=mof=0;
          setflg=0;
         int sethron()
         {   do
             clrscr();
            printc(" Set ON HR");
            if(rc0)
               hon=hon+1;
               go(64);
               print(hon);
               delay_ms(300);
               if(hon==24)
                  hon=0;
            else if(rc1)
               hon=hon-1;
               go(64);
               print(hon);
               delay_ms(300);
               if(hon==-1)
                  hon=23;
     while(!rd0);
     return(hon);
         int setmnon()
            do
            clrscr();
            printc(" Set ON min");
            if(rc0)
               mon=mon+1;
               go(64);
               print(mon);
               delay_ms(200);
               if(mon==60)
                  mon=0;
            else if(rc1)
               mon=mon-1;
                  go(64);
                  print(mon);
               delay_ms(200);
               if(mon==-1)
                  mon=59;
     while(!rd0);
     return(mon);
     int sethrof()
         {   do
             clrscr();
            printc(" Set OFF HR");
            if(rc0)
               hof=hof+1;
               go(64);
               print(hof);
               delay_ms(200);
               if(hof==24)
                  hof=0;
            else if(rc1)
               hof=hof-1;
               go(64);
               print(hof);
               delay_ms(200);
               if(hof==-1)
                  hof=23;
     while(!rd0);
     return(hof);
        int setmnof()
            do
            clrscr();
            printc(" Set OFF mn");
            if(rc0)
               mof=mof+1;
               go(64);
               print(mof);
               delay_ms(200);
               if(mof==60)
                  mof=0;
            else if(rc1)
               mof=mof-1;
                  go(64);
                  print(mof);
               delay_ms(200);
               if(mof==-1)
                  mof=59;
     while(!rd0);
     return(mof);
   void mode50()
      rd4=1;rd5=rd6=rd7=0;
      go(12);
      printc("m50");
   void mode0()
      rd4=rd5=rd6=rd7=1;
      go(12);
      printc("m0");
   void mode100()
      rd4=rd5=rd6=0;
      rd7=1;
      go(12);
      printc("m100");
I am using the compiler CCS 3.36
Anyone please check these?
Gabriel
PostPosted: Tue Apr 03, 2012 8:51 am     Reply with quote
so, what is your problem exactly?
expected results?
symptoms?
G.
CCS PCM 5.078 & CCS PCH 5.093
ratheeshbr
PostPosted: Tue Apr 03, 2012 5:55 pm     Reply with quote
Both RTC and GSM works independently.
But GSM is not working, means messages are not received by the controller. I tried to use interrupt but, not enough space.
PostPosted: Wed Apr 04, 2012 5:47 am     Reply with quote
couple of comments...
1) whenever you use the hardware UART, be sure to add 'errors' to the uses rs232(....) code !
2) NEVER enable any interrupt without having an ISR for it ! You enable INT_RDA but I can't se the 'handler' ( ISR) for it. Program will crash...
3) your timesetting code is very similar,so codespace could be saved by creating a common function and calling it instead of all the inline code you have.
4) you've coded the ldf() function to return a float,but the ADC will only return a 10bit integer.
5) go(xx) means what ???? either I can't see it or it's missing ?
