Problem with A/D - code included - please help
PeterDove
PostPosted: Tue Jan 23, 2007 8:49 am     Reply with quote
Hi All,
I have some problem with some A/D code I have written. I have 1.2ish Volts applied to AN1/RA1 on my PIC18F2550. I did not use AN0/RA0 ( is this a problem )
Now all I get is various random numbers from the ADC and sometimes I just get 0 and sometimes 1023 and also other numbers. To measure the A/D I just hook the voltage to the pin? Its the temperature pin coming out of a memsic 2125. When I measure the output from the pin it is showing 1.22
Below is the code - hopefully its something simple :(
#include <18F2550.h>
#device adc=10
//configure a 20MHz crystal to operate at 48MHz
#fuses HSPLL,NOWDT,NOPROTECT,LVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#include <usb_cdc.h>
#rom int 0xf00000={1,2,3,4}
long temp;
usb_init();
while(!usb_cdc_connected()) {}
setup_adc_ports( AN0_TO_AN1 | VSS_VDD );
setup_adc(ADC_CLOCK_DIV_8 );
set_adc_channel( 1 );
do {
temp = read_adc();
printf(usb_cdc_putc, "ADC 1 : %ld \n\r", temp);
delay_ms(5000);
} while (TRUE);
Please help Smile
Peter
PostPosted: Tue Jan 23, 2007 12:41 pm     Reply with quote
long temp;
usb_init();
Download the latest data sheet for the 18F2550:
http://ww1.microchip.com/downloads/en/DeviceDoc/39632c.pdf
Look at this table in the data sheet:
TABLE 21-1: TAD vs. DEVICE OPERATING FREQUENCIES
It's on page 265 (page 267 in the Acrobat reader).
Look at this column in the table:
Maximum Device Frequency
18Fxxxx
Locate the frequency that you're using (48 MHz). Now look over to
the left side of the table. What divisor value is recommended ?
Compare that to the one that you have in your code above.
PeterDove
PostPosted: Tue Jan 23, 2007 4:12 pm     Reply with quote
PCM programmer wrote:
long temp;
usb_init();
18Fxxxx
Changed it to
setup_adc(ADC_CLOCK_DIV_64 );
Though the output is still random? I assume when I set up them as analogue that thye are set up as inputs?
Peter
PostPosted: Tue Jan 23, 2007 4:21 pm     Reply with quote
Post your compiler version. It's a number such as 3.191, 3.249, 4.020,
etc. You can find it at the top of the .LST file, which is in your project
directory. Don't post any numbers that come after the version number.
PeterDove
PostPosted: Tue Jan 23, 2007 5:22 pm     Reply with quote
Its 4.020
Just in case it helps, I am taking the out from a parrelex/memsic 2125, its the temperature out and applying it straight to RA1. Also the memsic has its own power supply/circiut so the wire just runs from that circuit up to the RA1 pin.
Peter
PostPosted: Tue Jan 23, 2007 5:32 pm     Reply with quote
Do you have a ground connection between the Gnd pin on the Memec
and the Vss pin (i.e., ground) on the PIC ?
PeterDove
PostPosted: Tue Jan 23, 2007 5:38 pm     Reply with quote
No, do I need this, do I need to put a line between the ground of the PIC and the ground of the memsic. Both are separately powered circuits. Sounds like I am about to learn something Smile I really appreciate you taking the time
Peter
PostPosted: Tue Jan 23, 2007 5:47 pm     Reply with quote
Yes, you need a common ground connection between the two devices.
PeterDove
PostPosted: Tue Jan 23, 2007 5:51 pm     Reply with quote
Thanks a lot for your help - I was just hoping I could mash the circuits together but looks like I will need to build a whole new circuit. Shouldnt take me long though.
Peter
