pwhitey86
Joined: 11 Jan 2007 Posts: 9 Location: Philadelphia, PA, USA
| pwm weird output |
Posted: Mon Jan 22, 2007 3:27 pm |
hi i setup my pwm as such
EDIT: reposted code
#include <18F2680.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BRGH1OK) // Jumpers: 8 to 11, 7 to 12
char selection;
signed int16 value;
setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
setup_timer_2(T2_DIV_BY_1, 127, 1);
value=0x01FF;
printf("%4X\r",value);
set_pwm1_duty(value); // This sets the time the pulse is
but the output voltage is flat at 1.68 volts on the scope .... it is the same thing for all values of pwm duty from 1 to 255 ???
i am using a 18f2680
thanks
Posted: Mon Jan 22, 2007 4:46 pm |
Repost the code.
At the moment, what you have, makes no sense, with two trailing braces, and the code just setting up the PWM, and running off the end putting the PIC to sleep. Normally this is caused by not hitting the 'Disable HTML in this post' tick box, when posting code, which if left unticked, makes code unreadable...
pwhitey86
