Possible PWM Code??
weg22
Possible PWM Code??
PostPosted: Sat Jan 20, 2007 1:04 pm     Reply with quote
I found this post on the Microchip web site for generating PWM signals. Can anyone tell me how this could be written to compile with CCS?
Thanks in advance,
-weg
Here's an untested "software only" example driver for 8 channels using PORTB. As stated earlier in the thread, this solution may exhibit a one or two instruction cycle pulse width jitter.
Your Main program simply sets values in the Pulse array, Pulse[0] through Pulse[7]. Pulse[0] is output on RB0, Pulse[1] is output on RB1, and so on through Pulse[7] which is output on RB7. Pulse[8] is the end-of-period off time (20000 usecs minus the Pulse[0] through Pulse[7] on time values) where the Servo variable (and PORTB) = '00000000'.
I'd love to hear back from anyone who might be able to test this example driver. Please remember Timer 1 prescaler should be setup for 1.0-usec 'ticks' with whatever oscillator frequency you're using.
static unsigned char n = 0;
static unsigned int Pulse [] = { 1500, 1500, 1500, 1500,
                                 20000 };
static unsigned char Servo = 1;
 *  setup interrupt vectors                                      *
#pragma code high_interrupt = 0x08
void high_interrupt (void)
{ _asm goto isr_hi _endasm
#pragma code
 *  ISR (high)                                                   *
#pragma interrupt isr_hi
 *  K8LH Crazy-8 'Soft' 8-channel (Port B) Servo Controller      *
void isr_hi ()
{ if (PIR1bits.CCP1IF == 1)     // if CCP "compare" interrupt
  { LATB = Servo;               // output new Servo pulse
    CCPR1H += (Pulse[n]/256);   // update the "match" value
    CCPR1L += (Pulse[n]%256);   //  for this Servo pulse
    Pulse[8] -= Pulse[n];       // adjust end-of-period off time
    Servo <<= 1;                // and prep for next channel
    PIR1bits.CCP1IF = 0;        // clear CCP1 interrupt flag
    if (!(n = ++n % 9))         // if end-of-period (n=0)
    { Pulse[8] = 20000;         // reset the 20.0-msec period
      Servo++;                  // and reset Servo = 1
