few samples with ADXL213??
fbighouse
PostPosted: Thu Jan 18, 2007 8:19 pm     Reply with quote
I tried to write a lite code for measure a vibration...the acceleration data shows a sinewave... but when the frequency of vibration grows to around of 300Hz, it seems that some points are lost...so for lower frequency, there are more samples per cycle of sinewave and for high frequency, there are few sample per sinewave. Follow below a part of code, I use a calibration function to estimate the total period (high + low level = 1mS)(the total period is always the same), meas() lite code (I think) for measure (30 samples) of high level (duty cycle variation) and write this data in matrix. I don't use timers or ccp to do this, because I think be worst.??
I appreciate some idea to improve measure in high frequency.
#include <16F877A.h>
#include <input.c>
#include <string.h>
#fuses HS,NOWDT,NOPUT,NOLVP,NOBROWNOUT,NOWRT
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, bits=8, parity=N)
float period;
long hi_level[30];
char x[10], on[3], meas[5], ver[4], cal[4];
short int vib_stat=0;
// VIBRATION MEAS
void meas_vib ()
int i;
for (i=0;i<30;i++) { // record in matrix 30 samples of rise time
long hi_temp=0;
while( input(PIN_C4)) {} // wait fall edge on C4
while( !input(PIN_C4)) {} // wait rise edge on C4
while( input(PIN_C4)) // while HI count+1
hi_temp++;
hi_level[i]=hi_temp; // record in matrix
// CALIBRATION
void calibration() // calibration of period
long hi_temp=0, low_temp=0;
hi_temp++;
while( !input(PIN_C4)) // while LOW count+1
low_temp++;
period=(low_temp+hi_temp); // period is sum of increments in hi and low
PostPosted: Fri Jan 19, 2007 3:00 pm     Reply with quote
Look at the CCS example file which shows how to two CCP modules
to measure a pulse width:
c:\program files\picc\examples\ex_ccpmp.c
There is a Microchip Tips 'n Tricks article that describes how to do it
with one CCP module by switching to detect the falling edge after the
rising edge has been detected:
http://ww1.microchip.com/downloads/en/DeviceDoc/41214a.pdf
