first lcd
nina
first lcd
PostPosted: Fri May 18, 2007 7:37 am     Reply with quote
I wrote a simple program just to test a lcd.
Over lcd.c driver the conection of lcd is made on pin D. If I want change this conection and put on pin B what do I need to do
my program is
#include <16f877.h>
#fuses nowdt,noput,nobrownout,nolvp,noprotect
#include <lcd.c>
#use standard_io (B)
lcd_init(); //Inicia LCD
set_tris_b(0x00); /*PortB output*/
lcd_putc("Teste"); //write teste
here is my layout
http://pg.photos.yahoo.com/ph/fernandoazevedo.rm/detail?.dir=d40ascd&.dnm=8aabscd.jpg
thanks
PostPosted: Fri May 18, 2007 12:04 pm     Reply with quote
You need to tell the lcd driver to use Port B. You can do this by adding
the line shown below in bold to your program. Put it just above the
#include line for the lcd driver. Example:
#define use_portb_lcd 1
#include <lcd.c>
Also, delete the TRIS statement for Port B, and put a constant loop at
the end of your program. Put it just above the closing brace for main.
nina
tks
PostPosted: Fri May 18, 2007 1:18 pm     Reply with quote
thank you very much PCM PROGRAMMER...
It is woking
