PIC16F877A
Goto page 1, 2  Next
harrison_c
PIC16F877A
PostPosted: Mon Jan 15, 2007 1:40 pm     Reply with quote
Confused
Hi guys, I want to order PIC16F877 sample. But I am not sure what is the different between PIC16F877 and PIC16F877A. Actually, I have no experience about microcontroller. I have no idea about PIC16F877A-I/L, PIC16F877A-I/ML, PIC16F877A-I/P and PIC16F877A-I/PT. What are the difference between them? Which one I should get for beginner? Please advise, thank you.
Harrison
PostPosted: Mon Jan 15, 2007 1:50 pm     Reply with quote
I think the 16F877 is no longer in production (I think!), and the 877A has replaced it.
The information following the processor part # relates to package and temperature range. The "-I" means industrial temperature range, -40C to +85C. The "/L" means PLCC package, "/ML" means QFN package, "/P" is the 40 pin DIP package, and "/PT" is the TQFP package.
You'll want a package that easily fits into a ZIF (zero insertion force) socket or a solderless breadboard, which is the 40 pin DIP package: 16F877A-I/P.
Edit: you find this type of information in the processor's data sheet. There's usually a section called "packaging information" or "package types" or "ordering information". That's where you'll find an explanation of these codes.
PostPosted: Mon Jan 15, 2007 2:34 pm     Reply with quote
You can get the 16F877 from Digikey:
http://catalog.digikey.com/scripts/partsearch.dll?Detail?name=PIC16F877-20%2FP-ND
Digikey has a $25(US) minimum order.
You can get it from Mouser (no minimum order):
http://www.mouser.com/search/ProductDetail.aspx?R=PIC16F877-20%2fPvirtualkey57940000virtualkey579-PIC16F87720P
These are U.S. companies.
Farnell-in-One also has it.
http://export.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=9761373
They won't let me provide a direct link to the product.
If you're a complete newbie, it's best to buy a demo board rather than
attempting to build your own board. Here's a large thread where I
believe all the problems are due to a newbie attempting to make his
own board:
http://www.ccsinfo.com/forum/viewtopic.php?t=29412
harrison_c
how about....
PostPosted: Mon Jan 15, 2007 4:15 pm     Reply with quote
Thank you. By the way, what is PIC16LF877A?
PostPosted: Mon Jan 15, 2007 4:52 pm     Reply with quote
F = 5V part.
LF = low voltage (< 5V) part.
The LF parts will run at 3.3V. Depending on the particular processor, some will run at voltages lower than that.
Edit: The LF parts will also run at 5V too. The only thing to watch for is that the processors can't be run as fast at low voltages as they can at 5V.
treitmey
spec page 176.
fig17-1 compaired to 17-2
the 16LF877a works down to a lower voltage.
harrison_c
Development kit
PostPosted: Mon Jan 15, 2007 10:46 pm     Reply with quote
Hi PCM Programmer, I know it is much easier if I could buy Development kit. But it is very expensive, it costs $424.00.
Do you know any place I can get it cheaper?
by the way, I am not sure you are talking about this kit, please check it out.
http://www.ccsinfo.com/product_info.php?cPath=45_29&products_id=62#configure
PostPosted: Mon Jan 15, 2007 10:48 pm     Reply with quote
I'm not talking about an incredibly expensive kit, I'm just talking about
getting a cheap development board that supports a PIC in the 40 pin
DIP package.
w2drz
Re: PIC16F877A
PostPosted: Tue Jan 16, 2007 12:40 am     Reply with quote
harrison_c wrote:
Confused
Harrison
Why not purchase this kit, with out compiler, it is $99.00.
includes the programmer serial or USB as youi select in the purchase.
http://www.ccsinfo.com/product_info.php?products_id=16F877Akit
tom
PostPosted: Tue Jan 16, 2007 12:57 am     Reply with quote
This thread discusses some issues concerning which development tools
to buy:
http://www.ccsinfo.com/forum/viewtopic.php?t=26954
harrison_c
without compiler?
PostPosted: Tue Jan 16, 2007 1:33 pm     Reply with quote
Hi Tom. Once again, I am rookie. How does the job work if without the compiler? or I can get it from somewhere else?
PostPosted: Tue Jan 16, 2007 2:18 pm     Reply with quote
There's a CCS compiler demo that works with the 16F877, but it will
only use up to 25% of the available ROM space.
http://www.ccsinfo.com/content.php?page=compdemo
It won't work with the 16F877A. The "A" chip is a different chip
than the "non-A" 16F877 chip.
You need a compiler and a programmer, at a minimum.
Re: without compiler?
PostPosted: Tue Jan 16, 2007 3:02 pm     Reply with quote
You had asked about a low cost development board,
lost in the asking was that you did not have a compiler.
You need to look at the note from PCM programmer,
with his advice on your original question.
From your questions I would think you are a student, if so or not.
My suggestion would be to ask your (teachers or others) for help in forming a group with the same interest learning about digital circuits.
At this time from your questions asked, there is a need to form a study group about how to advance your knowledge and be able to do a group purchase of materials as needed. This would reduce the individual cost to continue your development of the subjects you are asking about.
tom
Idea
tojape
PostPosted: Tue Jan 16, 2007 4:48 pm     Reply with quote
Hi, Harrison,
why don't you try Microchip's PICkit 2 44pin demo board for $24, or PICkit 2 DebugExpress for $50, bundled with CCS PCB which may be sufficient to get familiar with MCU-s
The link is:
http://www.microchipdirect.com/productsearch.aspx?Keywords=DV164121
harrison_c
I wish there is a course...
PostPosted: Tue Jan 16, 2007 10:17 pm     Reply with quote
Hi guys, first of all I am not a student. I graduated from college in Toronto. And there is not a course really focusing on the microcontroller. I only learnt assembly language itself. We didn't use it to control hardware. Actually, I wish there is a course in Toronto about C programming and microcontroller. I am sure I will take it. By the way, I bought and started reading the book, "Embedded C Programming and the Microchip PIC". PIC16F877 is using in the book so that I am thinking to get a development kit or demo board to do experiments. Please advise me that what should I do next? I really like to learn microcontroller as much as possible but I don't know where I should start from. Thank you.
Honford
Goto page 1, 2  Next
Page 1 of 2
