USB CDC hangs
Kiwime
USB CDC hangs
PostPosted: Thu Sep 28, 2006 4:34 pm     Reply with quote
I am trying to use usb_cdc.h to stream data from a GPS unit to a virtual comm port. Everything works great when sending commands and receiving small amounts of data but when streaming data directly from the GPS to the virtual comm port I get a few pages of data and then it hangs. The comm port is still there, and I can still send commands to the PIC, but no data comes back to the PC. It's like the PC buffer gets full and doesn't flush or something... Anyone have any ideas??
while(!usb_cdc_kbhit() { //stream data until a key is pressed
i = timed_getchar();
usb_cdc_putc(i);
When I run this with the ICD and pause is after is hangs, it looks like it's waiting for usb_cdc_putready() to return true...
PostPosted: Thu Sep 28, 2006 4:45 pm     Reply with quote
Read this thread for problems with hanging. They suggest adding
large capacitors to do power supply bypassing on Vusb.
http://www.ccsinfo.com/forum/viewtopic.php?t=24308&postdays=0&postorder=asc&start=15
ymoona
PostPosted: Fri Jan 12, 2007 9:44 am     Reply with quote
I'm right now having the same problems, is it already solved?
checkout my site: www.ymoona.com/wiki
ymoona
PostPosted: Fri Jan 12, 2007 1:01 pm     Reply with quote
the problem is still there, I put some capasitors around it. but it slows donw the problem but does not eliminate it. Ik sghal also try it with some caramic capasitors (100n) to reduce noise. progress will be posted
ymoona
PostPosted: Sat Jan 13, 2007 4:29 pm     Reply with quote
still no pregress here
