		| Author | Message |
		| Paul Guest
				| Interpretation of the .lst file |
				|  Posted: Thu Jan 11, 2007 2:13 am |   |
				| Hi,
 Sometimes I look at the .lst file to see what the compiler makes of my c. Usually it is easy to see what statements generate what code. I recently had a question about a #USE rs232 that I needed to see the compiled code for. It took me a lot of time to realise that the code for this statement is in the beginning of the main() function and nowhere near the actual #USE rs232 statement in the list file.
 My question: could I have known that? Is there a way to 'know' where code is placed?
 Thanks,
 Paul Holthuizen
 PCWH 3.248
		| PCM programmer
				|  Posted: Thu Jan 11, 2007 5:42 pm |   |
				| See this FAQ article: http://www.ccsinfo.com/faq.php?page=lst_out_of_order
 Some of the initialization code for the #use libraries is put at
 the start of main().   For example, that's where the compiler
 puts the setup code for the UART if you specify #use rs232().
 The code that performs the UART functions is usually placed
 inline if it's short, such as the putc() code for a hardware UART.
 It's placed under the #use rs232() statement if it's longer code,
 such as for a 'soft' UART, or if parity calculations are required, etc.,
 because the compiler typically will 'call' that code instead of placing
 it inline.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
