| Newbie question about pin numbering |
Posted: Sat Jan 06, 2007 5:59 pm |
Hi, I'm new to PICs (having done a bit with BASIC Stamps). I'm trying to figure out how the port/bits map to pins on the microcontroller. My microcontroller (a PIC12C672) has 8 pins. If I wanted to make pin 7 high, what would I pass as a parameter to output_high?
Here's what the documentation on output_high states, but I must be missing some fundamental concept because I don't understand what the port and bits signify:
Pins are defined in the devices .h file. The actual value is a bit address. For example, port a (byte 5) bit 3 would have a value of 5*8+3 or 43. This is defined as follows: #define PIN_A3 43. The PIN could also be a variable. The variable must have a value equal to one of the constants (like PIN_A1) to work properly. The tristate register is updated unless the FAST_I0 mode is set on port A. Note that doing I/0 with a variable instead of a constant will take much longer time
[/i][/quote] |
Posted: Sat Jan 06, 2007 7:22 pm |
Look at the list of available i/o pins, which is given at the top of the
12C672.H file, and use those constants with the CCS pin i/o functions.
Example:
output_low(PIN_A0);
output_high(PIN_A0);
You don't have to consider how the constant is constructed, from
a port address and a bit number. Just drop the constant into the
function as a parameter, and it will work.
The 12C672.H file is in this directory:
c:\Program Files\Picc\Devices |
Posted: Sat Jan 06, 2007 8:58 pm |
Many thanks, I think I understand it now  |
