Alex Mackinnon
Reset on upgrade - WHY?!?! |
Posted: Fri Jan 05, 2007 3:34 am |
This is an application not a device driver... why the hell does it need a system reset whenever it is upgraded?
This just looks like more of the shoddy programming that seems to be IDE 4.
If I had previewed IDE 4 you would never have got the money out of me for an upgrade... it has improved, slightly, in the last builds but still hangs a lot when doing even trivial editing.
Not good... not good at all ![Sad](images/smiles/icon_sad.gif) |
Posted: Fri Jan 05, 2007 8:36 am |
The IDE, includes two device drivers, for interface to the MachX, and the ICD....
Alex Mackinnon
Posted: Sat Jan 06, 2007 4:53 am |
Which it should not install by default because not everyone has or wants those devices... shoddy programming! |
Mark
Posted: Sat Jan 06, 2007 12:36 pm |
You do realize that this is a user forum. And you can do all the screaming you want but all you are doing is yelling at customers instead of the manufacturer! |
