USB Driver
deniska_gus
USB Driver
PostPosted: Thu Mar 15, 2007 4:40 am     Reply with quote
Hi all,
i've got just one question. Where can i get an USB-Driver for PIC18Fxxx? Or should i write it by myself? How do you make it?
Regards. Dennis
Ttemah
PostPosted: Thu Mar 15, 2007 5:27 am     Reply with quote
A USB driver to do _what_?.
There are examples of implementing a CDC device, block IO device, keyboard/mouse device etc., all with their required drivers, in the 'examples' directory for the compiler...
deniska_gus
PostPosted: Thu Mar 15, 2007 5:38 am     Reply with quote
i am using PIC16 to comunicate with pc over rs232. Now i would make it over USB. But i don't know how i can do it, becouse i have not USB driver for this.
rberek
PostPosted: Thu Mar 15, 2007 6:06 am     Reply with quote
Then look at the CDC driver that Ttelmah referred to...
r.b.
meereck
PostPosted: Thu Mar 15, 2007 6:12 am     Reply with quote
If you are going to use the CDC firmware use PICC\Drivers\cdc_NTXP.inf as a PC driver for that device.
If you want to implement your own device with custom endpoints, you should use mchpusb.inf as a driver and import mpusbapi.dll into your PC end application.
