How to define array of pins?
40inD
PostPosted: Tue Jan 02, 2007 4:40 am     Reply with quote
I need to define an array like this:
Pins[3]=
{PIN_E0;
PIN_E1;
PIN_E2;
#define doesn't work.
PostPosted: Tue Jan 02, 2007 11:53 am     Reply with quote
You're really asking how to initialize an array. You need to use
commas as separators, not semi-colons. Example:
int16 Pins[3]=
PIN_E0,
PIN_E1,
PIN_E2
Note that for 18F PICs, the pin constants are 16 bits, so the array
must be declared as an int16 (as shown above). For the 16F series,
the pin constants are int8 values. This is shown in the .H files for the
PICs, in the #define statements for the pins.
