iw2nzm Guest
RC7 on PIC16F876(A) |
Posted: Sat Dec 30, 2006 4:36 pm |
Hi to all,
I can't use the RC7 pin as output. I know it's multiplexed with serial RX but when the SPEN is 0 it should work as output.
Here is the code:
#include <16f876a.h>
#fuses HS, NOWDT, PUT,NOPROTECT,BROWNOUT,NOLVP,NOCPD,NOWRT,NODEBUG
#use delay(clock = 16000000, RESTART_WDT)
#use fast_io(c)
#byte rcsta = 0x18
void main() {
set_tris_c(0x00);
rcsta = 0x00;
output_high(PIN_C7);
for (;;) {}
There is no hardware connected to the PIC. Other pins works fine and the oscillator runs.
May anyone help me?
Marco / iw2nzm |
Posted: Sun Dec 31, 2006 1:47 am |
Normally the Rx pin on the PIC is connected to the output of a
MAX232-type chip. The output of the MAX232's receive section
may conflict with the using pin C7 as an output.
What external circuit or chip is connected to pin C7 ?
Also, did you post your complete test program ? It's missing the
closing brace of main(). Is there more ? Is there a #use rs232()
statement in your program ?
What is your compiler version ? |
Posted: Sun Dec 31, 2006 2:33 am |
PCM programmer wrote: | Normally the Rx pin on the PIC is connected to the output of a
I forgot the closing brace when I did copy&paste. There are no other code and on the board there are only the PIC, the oscillator section (16 MHz crystal and two 22pF capacitor) and a 100 nF bypass capacitor on power supply.
I don't need any serial communication, just digital output on Port C.
My compiler version is: 3.6.0.99
I wish you a happy new year
Marco / iw2nzm |
iw2nzm Guest
Posted: Sun Dec 31, 2006 2:49 am |
I solved! There was a short on the board
I'm sorry for the useless thread
However, thanks for the support
Marco / iw2nzm |
