ICD-U40
semetu
ICD-U40
PostPosted: Wed Dec 27, 2006 1:20 pm     Reply with quote
I used first time ICD-U40. It is very nice. I want to same question.
1- in debug mode, at watch screen, I add the one varible (that is used in my program like below) this varible value only updated when I click the stop buton(red). why I didn't sea the variable value with updated form when running mode
int x=0;
main(){
while(true)
x++;
2-I have a USB developing kits with ICD-U40. If I make the new pic application developing card. Can I use the ICD-U40 with this card without adding any code to my pic? (Only I want to connect ICD-U40 and pic according to USB developing kits )
3-If I want to download the program to pic without ICD-U40. What can I do? In other words, I make same circuit and it is working and I want to dowload the my modification code to pic without disconnetting the pic from board.
TL
PostPosted: Thu Dec 28, 2006 4:42 pm     Reply with quote
1. Your variables in the watch window of the debugger do NOT get updated on the fly. You must set a breakpoint to view any variable contents. eg. Set a breakpoint on delay_ms(1000) and when it stops at that line, you can view the contents of 'x' (the counter).
2. I cannot comment because I have not used the CCS USB dev kit.
3. I'm not sure if I understood your problem. Basically if you don't use the ICD-U40, you have to program the pic using a programmer eg. Microchip PM3, Warp13A, etc.
