Splitting a 16 bit word into two 8 bit bytes |
Posted: Thu Dec 21, 2006 9:19 am |
I need to write a 16 bit variable to the internal EEPROM. I know that I can use the Make16 function to recombine two 8 bit bytes into one 16 bit word, but I can't find a reverse function. How do I split the 16 bit word into two 8 bit bytes?
Augie |
jamesjl
Posted: Thu Dec 21, 2006 10:14 am |
The answer is to use make8(); This is from the manual:
int32 x;
int y;
y = make8(x,3); // Gets MSB of x
davekelly
Joined: 04 Oct 2006 Posts: 53 Location: Berkshire, England
Posted: Fri Dec 22, 2006 1:50 am |
I use the following style, which can be expanded to accomodate 32 bit numbers as well
/// Write the specified byte to the EEPROM. Check if the data needs changing
/// first to avoid unnecessary saves.
void WriteEEPROM (int8 addr, int8 data)
if (read_eeprom (addr) != data)
write_eeprom (addr, data);
void WriteEEPROM16 (int8 addr, int16 data)
int8 * currentByte;
currentByte = &data;
WriteEEPROM (addr++, *currentByte++);
Posted: Fri Dec 22, 2006 9:07 am |
Davekelly,
Your code can be optimized. Working with pointers (16 bit) is not very efficient in a 8 bit PIC processor, also the increments in the last line of WriteEEPROM16 have no purpose.
Here an optimized version (now 34 bytes, was 84 bytes in the original)
Code: | void WriteEEPROM16_optimized(int8 addr, int16 data)
WriteEEPROM(addr++, make8(data,1));
WriteEEPROM(addr, make8(data,0));
Posted: Fri Dec 22, 2006 10:33 am |
Hi All,
OK, getting back to my original question, I seem to be having a problem with make8 and make 16. The problem is that these functions don't seem to work correctly in both directions. In other words if I use make8 to "de-contruct" a 16 bit word, and then use make 16 to "reconstruct" the I don't end up with the same value
int16 VoltsScaleFactor;
int8 Byte0, Byte1;
VoltsScaleFactor = 26475;
printf("Original VoltsScaleFactor: %lu\n\r", VoltsScaleFactor);
Byte0 = make8(VoltsScaleFactor, 0);
Byte1 = make8(VoltsScaleFactor, 1);
VoltsScaleFactor = make16(Byte0, Byte1);
printf("Contructed VoltsScaleFactor: %lu\n\r", VoltsScaleFactor);
When I run this code I see:
Original VoltsScaleFactor: 26475
Contructed VoltsScaleFactor: 27495
As you can see, the original and the re-constructed values are different.
What is going on??
Compiler is 3.249
Augie |
Posted: Fri Dec 22, 2006 10:42 am |
You have byte 0, and byte 1, the wrong way round when you reconstruct the word...
The high byte comes first in make16.
A an 'aside', I prefer the use of a union, to the make8/mae16 functions, since this is portable C to other compilers, and also makes it much easier to keep the bytes in the right order. There is no need to actually have seperate variables at all with this:
union joiner {
int8 b[2]
int16 w;
} VoltScaleFactor;
//Then
VoltScaleFactor.w=26475;
printf("Original VoltsScaleFactor: %lu\n\r", VoltScaleFactor.w);
printf("Byte 0 is :%u Byte 1 is: %u\n\r",VoltScaleFactor.b[0],VoltScaleFactor.b[1]);
You can read/write the bytes/word, at will.
