John676 Guest
PIC16F676 Won't Run |
Posted: Mon Dec 11, 2006 5:27 am |
Hi. I have tried a simple program with CCS PIC C that is supposed to turn on some LEDs, but it wont run. I know the pic works because I compiled the program in both Pic BASIC and in MPLAB and there were no problems there.
I think its got something to do with the configuration bits (or fuses as they are called in Pic C). I am setting the exact same fuses in MPLAB, so not sure what the problem is.
Here is the code:
#include <16F676.h>
#fuses INTRC_IO // Internal RC osc, no clock out
set_tris_a(0); // Make all outputs
set_tris_c(0);
OUTPUT_A(0xff); // Set all pins - turn on LED's
output_c(0xff);
I have also tried using the FAST_IO to set the data direction registers, but that didn't make any difference.
Thanks in advance for the help.
Regards,
John |
PhilWinder
Posted: Mon Dec 11, 2006 5:56 am |
I know how you feel, I hate these stupid, "why wont it start" problems. Could be a number of things,
Put in all the fuses in PICC, because every time you re-import your file in MPLAB, the HEX file will overwrite them. Better to just make sure there right by checking once, then forget about it.
I dont know about the chip you are useing, but the Comparator, A/d etc. have not been disabled.
So for an example, your file should have something like:
#FUSES NOWDT //Watch Dog Timer
#FUSES NODEBUG //Debug mode for use with ICD
setup_adc(ADC_OFF);
setup_vref(FALSE);
setup_oscillator(OSC_8MHZ|OSC_NORMAL);
Obviously, this is just a example and actual configuration may be different for your chip. Refer to the header file for your configurations (in the devices folder of PICC).
Cheers,
Phil |
John676 Guest
Hi Phil |
Posted: Tue Dec 12, 2006 5:20 am |
Hi Phil.
Thanks for the suggestions, I tried them but alas, no joy. I've tried just about everything I can think of, even different clock speed settings.
Nothing seems to work. I wonder if there is not some problem with CCS's pin assignments for this pic.
Thanks,
John |
Posted: Tue Dec 12, 2006 8:21 am |
Quote: |
I have tried a simple program with CSS PIC C that is supposed to
Post your compiler version. This will be a number such as 3.191,
3.236, 3.249, or 4.017, etc. Look at the top of the .LST file to find it.
The .LST file is in your project directory. |
rnielsen
Posted: Tue Dec 12, 2006 9:59 am |
Make sure you have a while(1) in your main so the program doesn't fall off the end and make the PIC fall asleep.
Ronald |
