CCSC.exe command line arguments
Hans Wedemeyer
PostPosted: Mon Dec 11, 2006 10:33 pm     Reply with quote
In a XP CMD window I type the following command
C:\PICC\CCSC.exe +FH +Y9 +ES +EA +PE I+"C:\PICC\DEVICES;C:\PICC\DRIVERS" C:\Source\TEST.C
This generates an error message:
Duplicate filename on command line. "I+C:\PICC\DEVICES;C:\PICC\DRIVERS" and "C:\Source\TEST.C"
I have also tried I+="C:\PICC\DEVICES;C:\PICC\DRIVERS" and it produces the same error.
What am I doing wrong ?
I'm using PCH V3.249 for this test.
Hans Wedemeyer
Strange fix...
PostPosted: Mon Dec 11, 2006 11:16 pm     Reply with quote
This did not work...
C:\PICC\CCSC.exe +FH +Y9 +ES +EA +PE C:\Source\TEST.C
This fixed it.... strange !
C:\PICC\CCSC.exe +Y9 +FH +ES +EA +PE C:\Source\TEST.C
Notice the order of +Y9 and +FH
I forgot to add I used Martin Berriman's suggestion of making a simple project file with the include paths in it.
if this is not in the command line args. I+"C:\PICC\DEVICES;C:\PICC\DRIVERS"
CCSC uses the project file.
So there is still an issue with I+ or I+=
