BUS CAN
kid_bengala
BUS CAN
PostPosted: Sat Dec 09, 2006 12:21 pm     Reply with quote
Hello:
Pardon by my English.
I´m new in the PIC and I want to make a reader of communications CAN, for them I have a PIC16F876 and a MCP2551 like controller, not very well like using bus SPI to be able to read the data, soon I want them to command by RS232 by a MAX232.
Somebody can put some code to me of example to use this?thanks
Greetings
PostPosted: Sat Dec 09, 2006 10:04 pm     Reply with quote
The MCP2551 is not a CAN bus controller. It's a bus transceiver.
It's function is similar to the MAX232 chip for RS-232. Data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/21667d.pdf
To use the CAN bus with a 16F876, you need an external CAN bus
controller chip, such as the MCP2510 or MCP2515. Data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/21801d.pdf
Driver file.
c:\program files\picc\drivers\can-mcp2510.c
c:\program files\picc\drivers\can-mcp2510.h
Example file:
c:\program files\picc\examples\ex_can_ccs_b.c
