function problem
deneme123
function problem
PostPosted: Tue Dec 05, 2006 8:40 am     Reply with quote
#if defined(__PCH__)
#include <18F452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,BROWNOUT
#use delay(clock=4000000 , restart_wdt)
#include<lcdnewe.c>
#define parametersAd 8
#define multiplier 16
//pin definition
#define MOTOR PIN_C0
#define FAN PIN_C2
#define CIRCULATION PIN_C3
#define DIRECTION PIN_C4
//pin definition
#byte intcon=0xFF2
//time variable
int workTime;
int32 seconds;
int times;
short mode; // surme yada bekleme olması 0 bekleme 1 surme
int timeVariableAdd[2] = {1,2}; // [0] bekleme [1] surme
//time variable
//menu variable
char menuItem[25];
int selection = 0;
int tempVariableAdd[3] = {5,6,7};//0 sirkulasyon,1 durma,2 calışma
char menuIndex[3];
//menu variable
//temp variable
int temp = 0;
int value = 0;
int16 tempSum = 0;
short situation; //0 ust deger altı 1 ust deger ustu
//temp variable
short begining;
short reverse;
int parameters;//situation changed 0,
int k=0;
void readTemp()
      restart_wdt();
      value = read_adc();
      if (tempSum == 0)
         tempSum = value;
         if (!(value <tempSum> (tempSum / times + 5)))
            tempSum += value;
            tempSum += (int)(tempSum/(times-1));
      restart_wdt();
      return;
void menu(int slc)
   restart_wdt();
   switch(slc)
      case 0:
         strcpy(menuItem ,"KAZAN SICAKLIK");
         strcpy(menuIndex ,"C");
      case 1:
         strcpy(menuItem ,"BEKLEME SURESI");
         strcpy(menuIndex ,"dk");
      case 2:
         strcpy(menuItem ,"CALISMA SURESI");
         strcpy(menuIndex ,"sn");
    /*  case 3:
         strcpy(menuItem ,"BEKLEME SURESI 2");
      case 4:
         strcpy(menuItem ,"CALISMA SURESI 2");
         break;*/
      case 3:
         strcpy(menuItem ,"SIRKULASYON POMPA");
      case 4:
         strcpy(menuItem ,"DURMA SICAKLIGI");
      case 5:
         strcpy(menuItem ,"CALISMA SICAKLIGI");
      case 6:
         strcpy(menuItem ,"GERI CEVIRME");
         strcpy(menuIndex ," ");
   restart_wdt();
   return;
#INT_RB
void menuItems()
   int valueb;
   valueb = input_b();
   delay_ms(40);
   if (valueb == input_b())
      valueb = valueb - (valueb%16);
      switch(valueb)
         case 0xD0:
            if(selection ==6)
               selection = 0;
               ++selection;
            menu(selection);
            lcd_putc("\f");
            lcd_gotoxy(1,1);
            printf(lcd_putc,menuItem);
         case 0x70:
            if(selection ==0)
               selection = 6;
               --selection;
            menu(selection);
            lcd_putc("\f");
            lcd_gotoxy(1,1);
   return;
   char i;
   set_tris_b(0b11110000);
   selection = 0;
   setup_adc_ports( RA0_ANALOG_RA3_RA2_REF);
   setup_adc( ADC_CLOCK_INTERNAL );
   set_adc_channel( 0 );
   lcd_init();
   lcd_gotoxy(3,2);
   printf(lcd_putc,"deneme");
   intcon = 0b11001000;
   readTemp();
   menu(selection);
   lcd_putc("\f");
   lcd_gotoxy(1,1);
   lcd_gotoxy(3,2);
   printf(lcd_putc," %u  ",value);
   lcd_gotoxy(9,2);
   printf(lcd_putc,menuIndex);
I use this code to change the menu items on the lcd but when add a code that calls the function menu it begins to reset itself what can be the problem
SherpaDoug
PostPosted: Tue Dec 05, 2006 1:40 pm     Reply with quote
Check the restart-cause() function to see why the PIC reset.
