deneme123
function problem |
Posted: Tue Dec 05, 2006 8:40 am |
Code: | #if defined(__PCH__)
#include <18F452.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,BROWNOUT
#use delay(clock=4000000 , restart_wdt)
#include<lcdnewe.c>
#define parametersAd 8
#define multiplier 16
//pin definition
#define MOTOR PIN_C0
#define FAN PIN_C2
#define CIRCULATION PIN_C3
#define DIRECTION PIN_C4
//pin definition
#byte intcon=0xFF2
//time variable
int workTime;
int32 seconds;
int times;
short mode; // surme yada bekleme olması 0 bekleme 1 surme
int timeVariableAdd[2] = {1,2}; // [0] bekleme [1] surme
//time variable
//menu variable
char menuItem[25];
int selection = 0;
int tempVariableAdd[3] = {5,6,7};//0 sirkulasyon,1 durma,2 calışma
char menuIndex[3];
//menu variable
//temp variable
int temp = 0;
int value = 0;
int16 tempSum = 0;
short situation; //0 ust deger altı 1 ust deger ustu
//temp variable
short begining;
short reverse;
int parameters;//situation changed 0,
int k=0;
void readTemp()
restart_wdt();
value = read_adc();
if (tempSum == 0)
tempSum = value;
if (!(value <tempSum> (tempSum / times + 5)))
tempSum += value;
tempSum += (int)(tempSum/(times-1));
restart_wdt();
return;
void menu(int slc)
restart_wdt();
switch(slc)
case 0:
strcpy(menuItem ,"KAZAN SICAKLIK");
strcpy(menuIndex ,"C");
case 1:
strcpy(menuItem ,"BEKLEME SURESI");
strcpy(menuIndex ,"dk");
case 2:
strcpy(menuItem ,"CALISMA SURESI");
strcpy(menuIndex ,"sn");
/* case 3:
strcpy(menuItem ,"BEKLEME SURESI 2");
case 4:
strcpy(menuItem ,"CALISMA SURESI 2");
break;*/
case 3:
strcpy(menuItem ,"SIRKULASYON POMPA");
case 4:
strcpy(menuItem ,"DURMA SICAKLIGI");
case 5:
strcpy(menuItem ,"CALISMA SICAKLIGI");
case 6:
strcpy(menuItem ,"GERI CEVIRME");
strcpy(menuIndex ," ");
restart_wdt();
return;
#INT_RB
void menuItems()
int valueb;
valueb = input_b();
delay_ms(40);
if (valueb == input_b())
valueb = valueb - (valueb%16);
switch(valueb)
case 0xD0:
if(selection ==6)
selection = 0;
++selection;
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
printf(lcd_putc,menuItem);
case 0x70:
if(selection ==0)
selection = 6;
--selection;
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
return;
char i;
set_tris_b(0b11110000);
selection = 0;
setup_adc_ports( RA0_ANALOG_RA3_RA2_REF);
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
lcd_init();
lcd_gotoxy(3,2);
printf(lcd_putc,"deneme");
intcon = 0b11001000;
readTemp();
menu(selection);
lcd_putc("\f");
lcd_gotoxy(1,1);
lcd_gotoxy(3,2);
printf(lcd_putc," %u ",value);
lcd_gotoxy(9,2);
printf(lcd_putc,menuIndex);
I use this code to change the menu items on the lcd but when add a code that calls the function menu it begins to reset itself what can be the problem |
