bootloader for pic16f877 @ 20mhz
PostPosted: Mon Dec 04, 2006 7:59 am     Reply with quote
Hi All
Could anyone please point me to where i can download a bootloader for the pic16f877 @ 20Mhz
PostPosted: Mon Dec 04, 2006 11:18 am     Reply with quote
This one works:
http://www.microchipc.com/PIC16bootload/
When you program it into your PIC, make sure that you disable
"Low Voltage Programming" mode in your programmer's Config Bits menu. The HEX file for that bootloader has LVP mode enabled, and
you don't want that. You need to disable it before you program the
HEX file into your PIC.
