leesing2k3
building application to detect thyristor effect in diode |
Posted: Tue Nov 28, 2006 4:53 am |
i am building an application to detect thyristor effect in a diode. in order to do so, a current from 0mA to 50mA need to be sourced to the diode to detect the thyristor effect.
So, i get AD558 to source a voltage from 0 to 10V and hope that i can use a resistor to control the current. But, AD558 is only able to source around 15mA.
Is there anyway that i can linearly amplify the current from 0 to 50mA? Resistor? Opamp?
Thanks in advance. |
adrian
leesing2k3
Posted: Tue Nov 28, 2006 7:52 am |
So basically I need an opamp to do the job? |
jecottrell
Posted: Tue Nov 28, 2006 8:58 am |
Google "programmable current source", "voltage to current converter", etc.
You can use a digital pot in a voltage divider to drive the source. (MCP41xxx part from Microchip is one option.)
That's just a start....
John |
