Controller Resetting
plzhelp
PostPosted: Mon Nov 27, 2006 5:38 am     Reply with quote
Hi everyone
In my code the PIC16f877a is randomly resetting. here is the code
#include <16F877A.h>
#device *=16
#fuses HS,NOPROTECT,NOWDT,NOLVP
#include<string.h>
#include<stdlib.h>
#include<stdio.h>
#use rs232(baud=19200,xmit=pin_E1,rcv=pin_E2,parity=N,stream=pc)
//switch is on C0-->C3
int value,i;
void switch_read()
    value = input_c();//use pull down resistors!!!
   for(i=4;i<8;i++)
      bit_clear(value,i);
     fprintf(pc,"\n\ri read:%u",value);
void switch_write()
    switch(value)
      case 1:
         output_c(0);
           fprintf(pc,"\n\routput: 0");
      case 2:
         output_c(1);
           fprintf(pc,"\n\routput: 1");
      case 3:
         output_c(2);
           fprintf(pc,"\n\routput: 2");
      case 4:
         output_c(3);
           fprintf(pc,"\n\routput: 3");
      case 5:
         output_c(4);
           fprintf(pc,"\n\routput: 4");
      case 6:
         output_c(5);
           fprintf(pc,"\n\routput: 5");
      case 7:
         output_c(6);
           fprintf(pc,"\n\routput: 6");
      case 8:
         output_c(7);
           fprintf(pc,"\n\routput: 7");
      case 9:
         output_c(8);
           fprintf(pc,"\n\routput: 8");
      case 10:
         output_c(9);
           fprintf(pc,"\n\routput: 9");
      case 11:
         output_c(10);
           fprintf(pc,"\n\routput: 10");
      case 12:
         output_c(11);
           fprintf(pc,"\n\routput: 11");
   setup_adc( ADC_OFF );
   fprintf(pc,"\n\rstart\n\r");
      output_low(pin_E0);
      delay_ms(40);
      switch_read();
      output_high(pin_E0);
      delay_ms(40);
      switch_write();
      delay_ms(3000);
I have also noticed that when i comment out the 'switch_write()' funtion then the controller does not reset.
Dont quite know whats going on
Many thanx
PostPosted: Mon Nov 27, 2006 6:27 am     Reply with quote
Realistically, probably electrical noise. What does output_c actually drive?. What suppression have you got close to the PIC?. How is your supply generated?. There is nothing in the code that wll itself 'cause' a reset.
However as a seperate comment, why store the same thing multiple times?.
void switch_write(void) {
   output_c(--value);
   fprintf(pc,"\n\routput: %d",value);
Is a hell of a lot simpler...
tsupuntu
EMI/EMC
PostPosted: Mon Nov 27, 2006 10:59 am     Reply with quote
I think Reset from trace PCB of your.You should learning Electromagnetic EMI/EMC
PostPosted: Mon Nov 27, 2006 11:05 am     Reply with quote
See this thread for links on the "random resets" problem:
http://www.ccsinfo.com/forum/viewtopic.php?t=27638&start=4
SET
PostPosted: Mon Nov 27, 2006 1:36 pm     Reply with quote
Cant see exactly what you are doing - but it does look like you read Port C, and then in 'switch_write' you write back out to Port C. But if you have pressed a switch and the output wants to go the opposite way then the processor will likely reset?
