how can I use interrupt and PWM on same port
MayDay
PostPosted: Mon Nov 27, 2006 4:50 am     Reply with quote
Hello
Please help me, how can I use interrupt and PWM on port B. For example I use PIC 16f88 and on pin RB3 I want to use PWM and on pin RB4 interrupts for an IR senzor. How can I do this. I use separatly PWM and Interrupts and works, but both doesn't.Pls hlep me.
PostPosted: Mon Nov 27, 2006 10:30 am     Reply with quote
You can't.
You need to use a seperate interrupt (RB0). The interrupt on the 'high' pins of port RB, is a 'port changed' interrupt. It triggers, whenever the state of a pin changes from the currently latched value. Unfortunately using a pin as a peripheral output, doesn't override this (hardware stupidity in the chip).
