I'm looking for a DAC board that all I have to supply is power and an interface. I was hoping there was a PIC eval board with an on-board DAC, but I haven't seen that. I'll gladly take all recommendations. _________________ -Pete
Then run wires over from your PIC prototype board (such as
PicDem2-Plus) to the Super Strip board. Also connect power and
ground. Then you can test your DAC. Of course, if you can buy
the DAC in a DIP-8 package, then you can just solder in a socket
on your PicDem2-Plus board and connect it to the Port i/o pins
with a few wires. That's the easiest way to do it.
kender
Posted: Tue Dec 26, 2006 11:32 am
There are simple DAC chips (in 8-DIP), that take only power and digital interface. For example: MAX538 with SPI interface and MAX517 with I2C interface. I think they are as simple to integrate as the board that you're looking for.
