bill conley Guest
| 18F6527 Internal A/D converters |
Posted: Wed Nov 15, 2006 8:27 pm |
For the 1st time ever, I'm having trouble reading the internal A/D converter of a PIC??
- I'm using the 18F6527 @ 10Mhz
- #device ADC=10
- setup_adc_ports(ALL_ANALOG);
- setup_adc (ADC_CLOCK_INTERNAL);
- All chanels return 1024?????
Code looks something like this;
set_adc_channel(0);
delay_us(100);
temp_ad = Read_ADC(); //
delay_us(200);
fprintf((COMM_PORT1),"+3Vdc: %lu\r",temp_ad);
set_adc_channel(1);
delay_us(100);
_dvdc_ = Read_ADC(); //
delay_us(200);
Thanks! |
Posted: Thu Nov 16, 2006 2:02 pm |
| Post your version of the compiler. |
bill conley Guest
Posted: Sun Nov 19, 2006 4:43 pm |
| Sorry...it's 3.249 |
Posted: Sun Nov 19, 2006 6:48 pm |
Did you check the NOLVP fuse?  |
bill conley Guest
| 18F6527 A/D Problem |
Posted: Sun Nov 19, 2006 7:20 pm |
Oh Gee, I wonder who this is???
- #fuses NOLVP,HS,PROTECT,NOWDT,PUT,BROWNOUT//,BORV45 |
Posted: Sun Nov 19, 2006 10:39 pm |
Did you declare 'temp_ad' as an int16 ? You need to do that.
If that's not the problem, then you should post a test program.
Copy and paste it in, from MPLAB. In other words, post a program
similar to what you posted above, but not code fragments. It should
be complete. |
bill conley Guest
Posted: Mon Nov 20, 2006 10:33 am |
Not int16 but long int, I think that's the same?
//read internal A/D on channel 0, (voltage input into controller)
void check_vin()
long int temp_ad = 0;
byte i;
set_adc_channel(_3VDC_REF);
delay_us(100);
_3vdc_ = read_ADC(); //
delay_us(200);
set_adc_channel(_5VDC_);
delay_us(100);
_dvdc_ = read_ADC(); //
delay_us(200);
set_adc_channel(_5VDC_REF);
delay_us(100);
_5vref_ = read_ADC(); //
delay_us(200);
set_adc_channel(_48VDC_PWS_MAIN);
delay_us(100);
main_pws_input = read_ADC(); //
delay_us(200);
set_adc_channel(PPD_DETECT);
delay_us(100);
_vpos_ = read_ADC(); //
delay_us(200);
set_adc_channel(_12VDC_PWS_OPAMPS);
delay_us(100);
_12vdc_ = read_ADC(); //
delay_us(200);
set_adc_channel(0);
delay_us(100);
delay_us(200);
//fprintf((COMM_PORT1),"+3Vdc: %lu\r",temp_ad);
set_adc_channel(1);
delay_us(100);
delay_us(200);
set_adc_channel(2);
delay_us(100);
delay_us(200);
set_adc_channel(3);
delay_us(100);
delay_us(200);
set_adc_channel(4);
delay_us(100);
delay_us(200);
set_adc_channel(5);
delay_us(100);
delay_us(200);
//for(i=0;i < 10 ;i++)
// temp_ad +=Read_ADC();
//_3vdc_ = ( (long int)(temp_ad/10)); //
main()
byte l_hr,l_min,l_sec,l_day,l_mo,l_yr;
byte remote_page_num = 0;
byte i;
long int long_i;
long int ad_1 = 0;
long int ad_2 = 0;
long int ad_3 = 0;
long int ad_4 = 0;
float num_1 = 0;
float num_2 = 0;
float num_3 = 0;
float num_4 = 0;
char Received; //Added for 2nd UART
char Received2;
int rxflag=0;
//EEPROM_ADDRESS address;
//init_ext_eeprom(); //init e2rom
enable_interrupts(int_rda);
enable_interrupts(INT_RDA2);
int_count=INTS_PER_SECOND;
set_rtcc(0);
setup_counters (RTCC_INTERNAL, (RTCC_DIV_256 | RTCC_8_BIT));
setup_wdt(wdt_off);
enable_interrupts (INT_RTCC);
disable_interrupts (int_ext);
enable_interrupts (int_ccp3);
setup_ccp3(CCP_CAPTURE_RE); // Configure CCP2 to capture fall
enable_interrupts (int_ccp5);
setup_ccp5(CCP_CAPTURE_RE); // Configure CCP2 to capture fall
setup_psp(psp_disabled);
//setup_adc_ports( ALL_ANALOG );
port_b_pullups(TRUE);
set_tris_c(0xBF); // Set pin C6 as an output
set_tris_g(0xFD); // Set pin G1 as an output
do
check_vin();
} while(TRUE); |
Posted: Mon Nov 20, 2006 12:30 pm |
Your test program is too complicated. Try this simple program
and see if it works.
#include <18F6527.h>
#device adc=10
#fuses HS, NOWDT, PUT ,BROWNOUT, NOLVP
#use delay(clock=10000000)
int16 result;
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
result = read_adc();
printf("%lx \n\r",result);
Posted: Mon Nov 20, 2006 3:30 pm |
You have a huge amount of stuff in your code, that has been remarked out. Remove this, and repost, _showing the declarations of the variables used to hold the ADC valuea_. Also use the 'code' buttons to post.
Also, consider using an array, or struture to allow the whole thing to be done with one loop. Something like:
structure values {
int16 threeDC;
int16 fiveVDC;
int16 fiveVRef;
int16 fortyeightVDC;
int16 PPDDetect;
int16 OpAmpPwr;
union {
int16 readings[6];
stucture values ADC;
} VIN;
void read_volts(void) {
int8 ctr;
for (ctr=0;ctr<7;ctr++) {
set_adc_channel(ctr);
delay_us(20);
VIN.readings[ctr]=read_adc();
//Then in your main:
while (true) {
read_volts();
printf("Three V line is at %d\n\r",VIN.ADC.threeDC);
Just showing how this would work for one value (but reading six).
A lot smaller, simpler to read etc. etc..
bill conley Guest
Posted: Mon Nov 20, 2006 9:17 pm |
Thanks Guys...I think I have it working. It wasn't the firmware, it was the hardware.
