PWM problem
jruibarroso
View user's profile Send private message Send e-mail MSN Messenger
PWM problem
PostPosted: Wed Nov 15, 2006 9:34 am     Reply with quote
if i use this , works fine :
int_count=INTS_PER_SECOND;
set_timer0(0);
setup_ccp1(CCP_PWM);
setup_counters( RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
setup_adc_ports(AN0_AN1_AN3);
enable_interrupts(INT_RTCC);
setup_timer_2(T2_DIV_BY_1,54,1);
set_pwm1_duty(110L);
if i use this , nothing happens on CCP1
set_pwm1_duty(110);
what is the mean of this "L" , i need to put a variable to replace fixed duty
and don't know what to do with this "L"
ex : set_pwm1_duty(duty); // this don't work
PostPosted: Wed Nov 15, 2006 10:23 am     Reply with quote
'duty, needs to be declared as a _long_.
This is the 'meaning' of the 'L' It forces the constant declaration to be treated as a 'long' type.
long int duty;
duty = 110;
Will work.
