Disassembly lising
Guest1
Disassembly lising
PostPosted: Wed Nov 15, 2006 4:47 am     Reply with quote
I am using MPLAB 7.50.00.00 with version 4.0.0.206 of the pch compiler.
The problem I get is that the code in the listing file is not in location order.
The problem this causes is that when a breakpoint is place in the 'c' file the 'c' code line does not allways line up with the actual code line in the disassembly file and so the break is placed elswhere in code
eg
   COLDstart:
   disable_interrupts(GLOBAL);                                   // 4 disable the interrupts.
   // Minor intialisation
   minor_init();                                     // 4+
   // Turns on Line reversal (if CLI) and RX interrupts
sleep_port_state();
The disassembly listing is as follows:
105:                  //***********************************************
106:                  COLDstart:
107:                  //***********************************************
108:                  disable_interrupts(GLOBAL);                                   // 4 disable the interrupts.
  2A42    9CF2     BCF 0xff2, 0x6, ACCESS
  2A44    9EF2     BCF 0xff2, 0x7, ACCESS
  2A46    BEF2     BTFSC 0xff2, 0x7, ACCESS
  2A48    D7FD     BRA 0x2a44
109:                  //
  26CA    062D     DECF 0x2d, F, ACCESS
110:                  // Minor intialisation
  26CC    522D     MOVF 0x2d, F, ACCESS
  26CE    E102     BNZ 0x26d4
  26D0    D002     BRA 0x26d6
111:                  minor_init();                                     // 4+
  26D2    D001     BRA 0x26d6
  26D4    D7D4     BRA 0x267e
  2A4A    EFA5     GOTO 0xb4a
112:                  // Turns on Line reversal (if CLI) and RX interrupts
113:
114:               sleep_port_state();
  2A4E    ECB5     CALL 0xb6a, 0
When I put a break at minor_init(); in the source code the break appears at the line after minor_init(); at
in the disassembly listing but the actual call to minor_init(); is two lines lower at
so when I run the program is never breaks at the correct time.
This is the first time I've used CCS with MPLAB and it may be something simple causing it but it's causing a nightmare to debug.
Does anyone know the soluiton to this.
Regards
PostPosted: Wed Nov 15, 2006 12:55 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=28808&highlight=disassembly
micro_joe
PostPosted: Thu Nov 16, 2006 3:03 am     Reply with quote
I have been using the disassembly listing but it's 70,000 lines long. (it's a port from an ST6 assembler application)
The real problem is that the listing is not in code location order ie it seems to have odd bits of code mixed in. If I could fix this then there would not be any problems.
Regards
micro_joe (formerly posted as Guest1)
