Stucture Identifier/Field Name Problem
jecottrell
PostPosted: Mon Nov 06, 2006 3:47 pm     Reply with quote
It appears the 3.236 compiler is having a problem digesting the following line:
if(assigned_sensor_array[i].status != assigned_sensor_array[i].rep_status) {
I get a "Structure Filed Name Required" error with the ".rep_status" characters highlighted. I tried reversing the order of the two values being compared. I tried enclosing each in an extra set of parenthesis. Nothing worked.
This solved he problem:
      tempstatus    = assigned_sensor_array[i].status;
      temprepstatus = assigned_sensor_array[i].rep_status;
      if(tempstatus != temprepstatus)
Am I missing something?
Thanks,
John
