Classes/ Structs in CCS C
huma
PostPosted: Tue Nov 07, 2006 12:28 pm     Reply with quote
Hello ,
i want to implement shortest path algorithm for my robot navigation in Pic16F877.
i tried this simnple one but it give error.
y it is so,are classes /structs suppoeted or not?
#include <16F877.h>
struct node
   int value;
   node n;                             //expecting a variaable here???
    while(true)
        output_d(0x00);
PostPosted: Tue Nov 07, 2006 12:50 pm     Reply with quote
If you're going to use that method of declaring a structure, then you
need to put the 'struct' keyword in front of the structure tag, as shown
in bold below:
struct node n;
Also there are no classes in C. The CCS compiler is C, not C++.
Ideally, you should learn these things outside of this forum.
huma
PostPosted: Wed Nov 08, 2006 7:00 am     Reply with quote
ok.i ll take care next time.
thanks
