need help for communicate with DS1624
farahnaz
PostPosted: Sat Nov 04, 2006 10:37 am     Reply with quote
Hello all,
i connected DS1624 to micro atmega128 AVR series in SDL and SCL line with pullup 4.7k. but anything happen. i dont know what is wrong and im in horry and stress with this project.
could anyone please help me?
thanks
Farahnaz.
PostPosted: Sat Nov 04, 2006 11:02 am     Reply with quote
This is a forum for support of the CCS compiler, on the _PIC_ microcontroller. Go and ask on an AVR forum.
farahnaz
PostPosted: Sun Nov 05, 2006 6:57 am     Reply with quote
If you read my query accurately you will underestand i want some information about DS1624 not micro. in addition i think anything change if you dont have any prejudice about ccs.
PostPosted: Sun Nov 05, 2006 9:00 am     Reply with quote
All available information about the DS1624 is in the data sheet. If you have all the wiring according to the data sheet (with the pullups) it is likely the problem IS with the MICRO or the programming, neither of which we can help you with here.
The most common causes we see for this type of thing are wrong connections at the cpu, incorrect pin setups or programming issues. ALL of these are MICRO/software related issues. As Ttelmah said, you will likely get better help in the AVR forum or the forum for the programming software you are using.
