Joined: 08 Sep 2003 Posts: 105 Location: New Castle, DE
I know that this is not PIC but looking for info on iTips
Posted: Fri Nov 03, 2006 7:00 am
The current tip that I have cut open is for an Nokia and the output voltage is 5V.
Now looking for information on the two resistors inside.
I would like to change the voltage output to 8V at 500mA.
Which resistor changes the voltage and which one changes the current limiting?
Making the resistors value small will that increase the voltage output or will increase the value increase the voltage?
Same question for the current?
Thank all in advance!
Tom
jecottrell
