adc with porta & port b as digital on pic18f4550
byatin
PostPosted: Mon Oct 30, 2006 1:04 am     Reply with quote
hi, i am using pic18f4550 microcontroller , i have to use port a pins ra0,ra1 as a analog and all port b pins as digital ,can anybody help me how to do it.
PostPosted: Tue Oct 31, 2006 1:26 am     Reply with quote
I am using pic18f4550 microcontroller , I have to use port
pins ra0, ra1 as analog and all port b pins as digital.
Look at the 18F4550.H file. The file is in this directory:
c:\Program Files\Picc\Devices
Scroll down near the end of the file. You'll see a section with this title:
// Constants used in SETUP_ADC_PORTS() are:
These are the settings that are used to configure pins as digital or Analog.
You said you're looking for a setting that will make pins A0 and A1 into
analog pins. Look in the list in the .H file. There is a setting for that.
Use that setting as a parameter in the setup_adc_ports() function.
If you want the Analog pins on Port B to be configured as digital pins
upon power-on reset, there is a fuse setting to do this. Add the setting
shown in bold below.
#include <18F4550.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT, NOLVP,NOPBADEN
