A/D conversion help
halides
View user's profile Send private message Send e-mail Yahoo Messenger
A/D conversion help
PostPosted: Sat Oct 28, 2006 4:16 am     Reply with quote
m using pic184550 uc, and cs4334ks d/a converter.
using the function
value = read_adc(ADC_START_AND_READ);
i send value to portB directly , on oscilloscope the output is showing but ambiguous.
can you tell me how to send each bit serialy to a single PIN .
jma_1
PostPosted: Sat Oct 28, 2006 8:55 pm     Reply with quote
Greetings,
I'm not sure I understand your question. The cs4334 ks is a two channel digital to analog (da)converter chip which receives data serially from a microprocessor. The read_dc(adc_start_and_read) sets up the analog to digital converter inside the pic microchip (read analog value at a micropressor pin). These are not related (one internal d/a measurement; one external serial write). Check out the datasheet for the cs4334 for setting up how to communicate with the chip (clock - internal or exteranl; two's complement data format, channel - L or R, etc).
Cheers,
JMA
