arunb
How many stack locations are used in this loop structure ? |
Posted: Mon Oct 23, 2006 10:30 pm |
I have the following code...
void save()
//a do while loop is implemented here
int16 func7(int h)
//a for loop is implemented here
void proc4(int nGroup,int nSelStep,int DevCode)
int j;
j=func7();
void proc5()
int g;
int func2()
proc5();
int16 func1()
int v,m;
v=func2();
v=func2();
m=func2();
m=func2();
return(make16(v,m));
do
if (bTransferFrom==1)
bTransferFrom=0;
for (n=0;n<2;n++)
T1=func1();
proc4(1,4,3);
}while(TRUE);
The above code shows the only the structure of the loops.
The code compiles well, and the LST file shows a stack usage of 7. Althogh the mcu works well sometimes for some reason it misses some operations , is it possible that the nested loop structure causes it to do so ??
thanks
arunb |
Posted: Mon Oct 23, 2006 11:37 pm |
Quote: |
The LST file shows a stack usage of 7. Although the mcu works
well sometimes for some reason it misses some operations.
Look for code that writes beyond the end of an array.
For example, suppose you have a string that is 16 characters long.
If you create an array as in the following code, the string will over-write
the 'i' variable when you copy a string to the array.
That's because a string has a 0x00 byte at the end. It's really 17 bytes
long -- 16 characters, plus the 0x00 at the end.
char array[16];
int8 i;
If the 'i' variable is being used to count iterations in a for() loop,
the code could behave in an erratic manner, and it could appear
to "miss some operations". |
