if(state < 0x80) //Master is sending data
incoming = i2c_read();
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer[address] = incoming;
if(state == 0x80) //Master is requesting data
i2c_write(buffer[address]);
I tried to simulate it on PROTEUS - ISIS.
I had to replace
if(state == 1)
to
if(state == 0)
and
if(state == 2)
to
if(state == 1)
to make it work.
Where's the bug? CCS or PROTEUS?
(I didnt try it physically)
Posted: Thu Nov 02, 2006 1:07 am
The i2c_isr_state() function looks at the DA and RW bits in the SSP
control registers. If Proteus emulates those bits incorrectly, then
you will have a problem.
If you want to research it further, here is some more information
on the i2c_isr_state() function:
